RV.Net Open Roads Forum: Truck Campers: Hole in my hot water line
 > Hole in my hot water line
Page of 5
pezvela
San Carlos, Sonora, Mexico
Posted: 06/29/12 10:12am Link  |  Quote  |  Print  |  Notify Moderator
wnjj wrote:
Can you just cut the pipe off and move the drain valve up to use it as a plug temporarily?
I could, but accessing it would be through a panel with six screws, instead of the conventional access door on the side. Not convenient.
JoeChiOhki
Sauvie Island, OR
Posted: 06/29/12 10:54am Link  |  Quote  |  Print  |  Notify Moderator
What confuses me is why there's even a back and forth on this. Get out your ratcheting pipe and tubing cutter, snip out the bad section, push a sharkbite in it's place.
Hole gone, problem fixed, no beating around the bush.
CB Channel 17 Redneck Express
d3500ram
colorado
Posted: 06/29/12 11:00am Link  |  Quote  |  Print  |  Notify Moderator
OP's comment on page 2:
You have to realize that, living in Mexico, it's not a simple matter of popping down to the Ace or Lowe's when you need something. I'll have to get it on my next trip to Phoenix in mid July.
pezvela
Posted: 06/29/12 11:53am Link  |  Quote  |  Print  |  Notify Moderator
The experimental rivet fix with the marine sealant has been holding for two hours under pressure with hot water. Interesting.
Take it easy, Joe. I'm not making this a permanent fix. I do appreciate your concern, though.
mkirsch
Rochester, NY
Posted: 06/29/12 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
The as seen on tv product you are probably thinking of is MIGHTY TAPE.
It's a stretchy silicone tape that sticks to itself.
I can verify that it works on non-pressurized applications for sure. In fixing my house kitchen sink drain I must have disturbed the brass/PVC interface, and it leaked.
The leak is in a nearly inaccessible area and I needed a RIGHT NOW solution. I wrapped the area with the mighty tape and it hasn't leaked a drop in over a year.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
JoeChiOhki
Sauvie Island, OR
Posted: 06/29/12 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
SharkBite Plumbing - Shipping
Shipping Charges Outside the Contiguous U.S.
If you are located outside the Contiguous U.S., please call us at 952-898-6000 for rates.
pezvela
Posted: 06/29/12 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Joe, have you ever tried to deal with shipping, Mexican customs or the postal service in Mexico? I would guess not.
wnjj
Cornelius, Oregon
Posted: 06/29/12 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
This would be temporary until you can get the proper fittings, if your current solution doesn't hold up. It doesn't need to be convenient.
JoeChiOhki
Sauvie Island, OR
Posted: 06/29/12 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
No, I can say I haven't and can be guaranteed I never will. I usually deal more in customs issues when I import things from Canada and Japan.
Perhaps your experiences will end up a good educational lesson for all our members here to remember to bring a full assortment of replacement parts with them for all their RV's systems when traveling south of the border.
LanceDuyen
Houston, TX, US
Posted: 06/30/12 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Any kind of electrical tape, duct tape or even a small piece of rubber innertube or rain coat, placed over the hole and secured with a hose clamp. Done.
Page of 5
