RV.Net Open Roads Forum: Class A Motorhomes: windshield cover
 > windshield cover
Bounder Billy
Colorado
Posted: 06/29/12 10:36am Link  |  Quote  |  Print  |  Notify Moderator
X3 on Reflectix from Home Depot or Lowes. 10' x 4' is about $25, and it is a quick fix to your heat issue, even if you eventually buy more expensive shades. The Reflectix really cuts down on the heat in the front of the coach and the A/C does not have to work as hard.
2008 Expedition 38F
2002 Jeep Liberty Sport
wny_pat
Western NYS
Posted: 06/29/12 10:50am Link  |  Quote  |  Print  |  Notify Moderator
03 RoadKing wrote:
I have Sunguard on my coach with the suction cups. They are as easy to install as the one's with magnetics without having to mount or drill any holes in the coach.
I made my own using similiar material that I got a Home Depot and suction cups from one of the commerical sites that sells RV window covers and suction cups for them.
tahiti16
Camarillo, CA
Posted: 07/03/12 12:15am Link  |  Quote  |  Print  |  Notify Moderator
We have the MCD and are very happy with them. They do a good job of reducing the heat while still letting us see outside.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
ryanallie1
Magalia, Calif
Posted: 07/03/12 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Ji All.
X2. We made our own from Home Depot also, 10x20 less than $40 dollars. Its in the "Gardening Department". Bought the "Suction Cups"cheap on line.
The way we made ours, is we can use them on the "Inside" or the "Outside", our choice.
Its a nice option to have, depending on the weather.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
Valkyriebush
Yuma/Port Townsend
Posted: 07/03/12 07:58am Link  |  Quote  |  Print  |  Notify Moderator
X2 on Prompt. I have the wheel covers also. WARNING on the wheel covers. They mount at the top with suction cups also but need to be anchored down at the bottom or they can do paint damage in windy weather. There is a metal bar at the bottom that can slide out and strike the RV in heavy winds. I have one compartment door with 15 paint dings because of this design flaw. I use to put a brick on each one to hold the bottom down. I had the seams sewed shut so the the rod won't slide out and mounted two clips on each side at the bottom to keep it down in the wind. Hopefully Prompt has fixed this. The material is top notch and the window cover mounts very easy (one man job) hook and suction cup. I like the see out not see in feature. Very strong. Fair price.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
Rich D.
New England
Posted: 07/03/12 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Before you buy any shade check out the Magne Shade. No suction cups, no wires, no bungees, no wrinkles, etc. 10 seconds to put on.
Magne Shade Home Page
First Time Installation
10 Seconds to Install
Rich D. Wanderlodge M450 LXi
topflite51
In The Desert of Nevada
Posted: 07/03/12 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Ours have snaps. On uneven ground and on a ladder, not fun. There has been a couple of times that I couldn't install because standing on a ladder was not an option. To remove is not a problem, I use the awning hook and pop the snaps with a twist. I would think that using twist locks would be a pain to use, especially removing them in the rain.
David
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to golf or fish
Simply Despicable
Any errors are a result of CRS.
 > windshield cover
