RV.Net Open Roads Forum: Forum Technical Support: AC not working with Generator
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > AC not working with Generator
mentler
ct.
Posted: 06/28/12 06:16pm Link  |  Print  |  Notify Moderator
Help, Took the rv out for a test drive today, turned on the generator, Onan 4,000, turned on 2 Ac units, both worked great, than Generator went off. When we got back hom tried the Gen, no AC, but every thing else worked. Switched to land Electric and both Ac units worked but not at same time. Checked circut braker in Rv OK. Now what??
Us out West
Let's see...last night we stayed in......
Posted: 06/28/12 06:20pm Link  |  Print  |  Notify Moderator
Another topic in the wrong forum.
Our Trip Journal
2012 Jayco Pinnacle (View)
36KitchenPantryTripleSlide
MorRyde pin box and suspension
Curt Q24
Dual Pane windows
Auto Levelers
2 AC's
And more...
2009 Silverado 3500HD 4X4 (View)
CC,
Dura-Max 6.6/Allison
LB
DRW
American Tank 65 gal. Aux Fuel
mentler
ct.
Posted: 06/28/12 06:24pm Link  |  Print  |  Notify Moderator
Sorry, New and entered this subject in wrong Forum. Will Try to do better.
D.E.Bishop
Eagle Rock, CA
Posted: 06/28/12 06:43pm Link  |  Print  |  Notify Moderator
Mary, How could you make such a stupid misteak? None of the rest of us have ever done anything like that. Oh Dear, Oh Dear, what we we do with you?
I don't remember what type of RV you have so I'm going to post this, reread your post and then continue to berate you.
Okay, I would guess you have either a A or a C, in either case the answer is praobably the same and at the worst very simple for someone who has been on here for better than ten years. I would bet there is a reset or circuit breaker that is tripped. Not many resets on AC units. Could be your transfer relay, that transfers the source of power from the gen to shore power or vise versa, I have to think about that for a minute. Whatever is wrong is most likely very simple. You should have several circuit breakers not just one, trip and reset all of them. It seem to me that if everything else is working, the transfer relay is good and a breaker is tripped. I don't want to befuddle you with all sorts of technical questions(no offence ment) so try that first and post what type of RV you have and if you have 30 amp service or 50 amp service. If you don't know the main breaker should tell you that, also it is in the manual. Maybe the dealer who sold to you could help.
Good Luck and get your post right next time, OKAY?
Dave
* This post was edited 06/28/12 06:53pm by an administrator/moderator *
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
PapPappy
Wilmington, NC
Posted: 06/28/12 06:52pm Link  |  Print  |  Notify Moderator
Are you sure that the generator is actually putting out to the RV, now that you restarted it. Do you have enough battery back-up to use the inverter, to make it appear that the other 110VAC outlets were working?
Also kind of surprised that you only have 4,000W Onan when you have two A/C units....that would be pretty close, if not in excess of the maximum that generator could put out. You may have trip the Generator's Circuit Breaker, if it has one? You may have to only run one A/C at a time?
Not knowing what you have for a rig, or the way it's power distribution is set up, you may want to start working backwards from the A/C units, to the Distribution panels....
Are you getting any 110VAC when the Inverter is shut-off? and the generator running? (maybe disconnect the battery?) Again, not knowing how your rig is set up, makes this difficult. Sorry
As for being in the wrong forum, I'm pretty sure that the moderator will shift this when he see it, and you will probably get more help. But it would have been nice of U.O.W. to be helpful, rather than get picky.
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
Us out West
Posted: 06/28/12 07:07pm Link  |  Print  |  Notify Moderator
I appologize for going off in your topic...it's that I see the high number of threads in this forum that have to get moved by the Mods which takes their time away from doing other things.
Good luck with your issues and I'm sure others in the know about them will get you some suggestions.
Our Trip Journal
Curt Q24
Dual Pane windows
Auto Levelers
2 AC's
And more...
CC,
LB
DRW
marcus6701
Central PA
Posted: 06/28/12 07:25pm Link  |  Print  |  Notify Moderator
I believe the 4000 watts is not enough for (2) ac units. They take quite a few amps each and may have been too much for the generator. I would try each one separate and see what happens. I'm assuming the ac units are 13,500 each. They run around 12-15 amps each, that would be a total of 24-30 amps just for the ac units. Not enough for anything else. Just not enough watts I believe. Good luck.
2008 30ft Aerolite, white interior, 2003 Suburban 6.0L 3.73 gears
mentler
ct.
Posted: 06/28/12 07:57pm Link  |  Print  |  Notify Moderator
Thank you all for your suggestions, tomorrow we will check and make sure the gen is putting out power and not just the inverter. Hope we didn,t fry the gen. Leavig on the 12th for Ga. Will let you know what we discover. Kep your fingers crossed.
smkettner
Posted: 06/28/12 07:59pm Link  |  Print  |  Notify Moderator
Did you check the breakers on the generator?
675 watts solar
pulsar
Lewisville, NC
Posted: 06/28/12 08:44pm Link  |  Print  |  Notify Moderator
This is a double post and is now closed. If you would like to comment on this topic or see what other have posted, you can do so here.
