RV.Net Open Roads Forum: Well that wasn't a pleasant first trip . . .
 > Well that wasn't a pleasant first trip . . .
tpcollins
Saline, MI. 48176
Posted: 06/29/12 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
We had our first trip only a short distance to one of our favored camping park for 3 nights and left for home this morning. Shortly after getting on the expressway a guy pulled up along side pointing towards the back of my rig. I got out and walked back and noticed my wife's Liberty leaning to one side. I thought flat tire in this heat! As I walked around I realized the front wheel was missing! The guy who flagged me down also stopped and told me my tire was laying in the median about 2 miles back! I went back and got the tire and tracked how far the scrape marks were in the road back to the Liberty - exactly 2 1/2 miles.
The tire didn't look tore up, just out of air. But the inside of the rim was all tore up and all of the bolts had ripped out of the rotor housing. I double checked the steering was unlocked before we left and check it again when I pulled over. So I assume a flat tire at 59 mph is not a good thing to have happen when towing a vehicle . . . !
Tim Collins
1995 Newmar 35' Dutch Star diesel pusher, acquired 1/21/05
TZScales
Maryland
Posted: 06/29/12 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Sure glad you did not have any major mishap and that your toad was not severely damaged. It seems that you have a quite simple repair. Safe travels.
TZS and Wife
2007 Monaco Executive Sandia IV
Cummins ISX 525 Horsepower
Allison 4000 Six Speed Transmission
Roadmaster Chassis
2006 Saturn Vue
SMI Air Force One
Larry Cohen
Mobile, AL
Posted: 06/29/12 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
That just shows the importance of a tire pressure monitoring system
2006 Mountain Aire 43
Short haired wife, long haired daschund and 3 sugar gliders are co-pilots, along with Garmin Nuvi 855
05 Honda Pilot with Air Force One supplemental brake
Blue Ox Aventa II towbar
Whirlpool Residential Fridge !!!
barlow46
Edgewater, FL
Posted: 06/29/12 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Tim, I think there is more to it than that. Something caused that wheel to tear away. Either it had a loose lug and gradually wore out the hole in the rim causing it to fail or bearing failed and it worked loose. Is that model a front wheel or rear wheel drive? Take a close look at that rim, my guess is you had a lug nut/bolt work loose.
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
PatrickA51
Lost
Posted: 06/29/12 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
One side of this is your toad is damaged.....the other side is no one was hurt.
It could been or caused a major accident.
Good Luck
wallynm
Los Alamos NM
Posted: 06/29/12 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
I know for a fact that I can not tell when I have a flat on a FROG.
Tire Failure
It makes no difference if you have a wheel or hub failure. Once the tire separates then you get an alarm. I have never seen a wheel failure on a FROG but I have seen one wheel failure on a trailer. When I stopped to help you could see the entire set of lug bolts were still attached to the drum. The entire center of the wheel was retained on the drum but the remaineder of the wheel assembly and tire were long gone.
DONATE THAT OLD CELL PHONE TO SUPPORT SOLDIERS click here
Have a Diesel Engine Diesel RV Club
Have a Freightliner Yahoo Group or FCOC Web Page
2002 DSDP 3567 PUSHED BY KITTY KAT
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
PapPappy
Wilmington, NC
Posted: 06/29/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
It may not have been the trip you wanted, but you made it home unhurt, and that is the goal of all of us!
The toad can be fixed.....
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
352
Oxfofd, Fl
Posted: 06/29/12 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
REMEMBER WHEN? MEMORIES.
* This post was edited 06/29/12 03:55pm by 352 *
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters
just a good ole southern redneck country boy
Come visit with us and swim with the Manatees
Go Dogs
South of Pittsburgh, PA
Posted: 06/29/12 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
That's pretty scary. I know I keep checking that the bikes are still on the bike rack, I can't imagine pulling a toad and not being able to see it.
Gsmitty77
San Diego
Posted: 06/29/12 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Glad no one was hurt! Best kind of problem - one where you write a check for the deductible...
Now that you have this one behind you, clear sailing wishes from Smitty!
Best,
Smitty
