RV.Net Open Roads Forum: General RVing Issues: Onan generator.....
 > Onan generator.....
flatbedr
Mid West USA
Posted: 06/29/12 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
This will be our first time dry camping. The 5er has a 5500 watt Onan quiet generator. How "quiet" is this genny? I also have a Yamaha 3000 inverter I can take along. We'll need to run the AC almost constantly. The biggest concern is being as quiet as possible at night. Thanks for the help!
Bert-64
Southwestern Ontario
Posted: 06/30/12 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Yamaha is the way I would go. We have a kipor 3000 we take for extended dry camping. The 5500 uses a lot more fuel. ( almost double ).
If your onan is propane powered it will use about 3 lbs per hour at half load.
Yamaha is going to be quite a bit better for noise also.
Tell a man that there are 400 billion stars and he'll believe you. Tell him a bench has wet paint and he has to touch it.
2001 Winnebago Brave 32
1999 Jeep TJ
10' Zodiac w/ Mercury 4hp
edatlanta
Panama City Beach, FL
Posted: 06/30/12 05:09am Link  |  Quote  |  Print  |  Notify Moderator
I have the Onan 5500 and running a single a/c and microwave occasionally during the day it will run approx 20 hours on 10 gallons of gasoline.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Handbasket
Asheville, NC
Posted: 06/30/12 05:21am Link  |  Quote  |  Print  |  Notify Moderator
If you're staying in a campground, they probably have quiet hours when generators are not allowed.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 06/30/12 06:13am Link  |  Quote  |  Print  |  Notify Moderator
The Yamaha is quieter than the Onan. I have an Onan 5500 and a Honda 2000 and have found the Yamaha 3000 that my buddy has is quieter than either of them.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
blangen
South Dakota... and everywhere.
Posted: 06/30/12 07:09am Link  |  Quote  |  Print  |  Notify Moderator
If your question is... Which one is quiet enough to run during "quiet time"? None of them. Not trying to be a downer, just informative. Reading between the lines, that's what it sounds like you're asking.
ryanallie1
Magalia, Calif
Posted: 06/30/12 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
One of the reasons we keep our Twin Honda's, Paralla Kit and Extended Run Tank, when we sold our 5er.
Our Honda EU2000i's are for sure a lot quiter and uses a whole lot less gas.
We also have a 5.5 Built In Generator. We use both to keep them working correctly.
Since we mostly do all Boondocking, we don't worry about noise anyways.
We can ever run what ever we choose to, and go beyond our Motorhomes 30 amp
limit.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
pnichols
Santa Cruz Mountains
Posted: 06/30/12 08:42am Link  |  Quote  |  Print  |  Notify Moderator
If you'll be caught up in the heat wave covering much of the U.S. during your upcoming camping, then my sympathies go with you!
You might want to camp where you can run your generator all night so you can get some sleep - there are places where you can do this. Even in normal quiet time campgrounds, if the unusual summer heat keeps up then I suspect more and more folks in parts of the U.S. will begin to ignore nighttime no-generator-rules this summer in order to make it through their camping trips.
Your biggest problem with the 5500 watt Onan may be fuel consumption. If you're real lucky, you may get around 2 and 1/2 hours of runtime per gallon of gasoline on it, but more like 2 hours, as the other poster above mentioned.
We use a green spark plug and Mobil 1 EP synthetic oil in our 4000 watt Onan to drive it's fuel consumption as low as possible and do get at least 2 and 1/2 hours per gallon when running the air conditioning. It's installed well enough and just a bit quieter with these two changes, so as to not be too irritating when running ... especially in the camping spots we usually wind up in.
Phil, 2005 E450 Itasca 324V Spirit
