I know cilantro is used in homemade salsa but how else do you use it ? I planted some this year for the first time. It's beginning to flower, so should I nip off the blossoms ?
You don't want it to bolt. I'm not a fan of celantro but it goes well with anything Mexican. Try it in your Chili recipe,you can make a pesto out of it, if you like that. I think its an aquired taste so go easy at first. If it does bolt, I think you can save and use the seeds - coriander.
I used some in a Chicken recipe last week....don't know if it made much difference. It was part of a marinade, and quite good. Sorry, I don't have the recipe with me, so can't post it now.
I guess if you've got it, and want to find uses, you could always do a Google Search: "Cilantro Recipes"
Bill & Claudia / DD Jenn / DS Chris / GS MJ Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293 The Pets
I use chopped fresh celantro on salmon filets with some Kikomann soy sauce. Place salmon on aluminium foil after brushing both sides lightly with butter. Drizzle a littel soy on the flesh side and rub in. Add chopped celantro, seal up and BBQ. Quick cook say, 3 or 4 minutes per side depending on the thickness of the filets. If using sockeye, cook time is much less. Serve with a savory rice pilaff and a tossed green salad.
Vic
Lack of common sense is the greatest mental illness known to mankind.
Use it in Thai type dishes. Make cold sesame noodles with peanut butter, sesame oil, beef stock, touch of honey, rice wine vinegar, chopped chives and cilantro. Yummy on noodles or on grilled chicken.
Usually a good idea to plant or buy another plant after about 6-8 weeks as once it starts to bolt, it gets stronger tasting. I usually start some seeds about 2 weeks apart all spring and summer as the warmer the weather, the faster it bolts. I like to "sprinkle" it on just about any Mexican dish but especially tacos, quesadillas, enchiladas, well, just about anything Mexican!
Use it fresh ... on top of salmon or any fish dish, any chicken dish, in any cream sauce, tacos, salsa, salad dressings ... anyplace you might put parsley. Use the leaves, not the stems ... and once it flowers it gets tough. It is also called coriander ... either the leaves or the seeds. When the seeds are crushed, it tastes different than the leaves ... slightly lemon like. Gotta use the fat round leaves, once it bolts the leaves get slim and long - not as tasty.
