RV.Net Open Roads Forum: Class A Motorhomes: air / vacum pump ???
 > air / vacum pump ???
lathe11
saugerties, new york
Posted: 06/30/12 10:31pm Link  |  Print  |  Notify Moderator
Have 1999 coachman sportcoach 380dp. There is a pump in my water department next to my black water handle . Problem no one knows what it is. It is wired and looks like a vacum pump based on the line coming off it, any suggestion as to what it may be???
farmer_boots
Weirsdale, Fl
Posted: 07/01/12 04:25am Link  |  Print  |  Notify Moderator
Any chance you can post a picture?
2006 Monaco Diplomat
bsinmich
Holland, MI
Posted: 07/01/12 05:23am Link  |  Print  |  Notify Moderator
It could easily be a vacuum pump. A DP does not create any manifold vacuum like a gas engine so many used to use a vacuum pump to give a vacuum supply to the cruise control.
1975 GMC Eleganza II & 1995 Roadtrek Versatile. Both old enough to vote and drink (gas)
barnaclebill
Atlanta Michigan or towards the sun
Posted: 07/01/12 05:52am Link  |  Print  |  Notify Moderator
12 volt, fresh Water pump? or macerator waste pump?
2003 41' Newmar Mountain Aire
400 Cummins
Jeep Liberty
Blue Ox Brake Buddy
lathe11
Posted: 07/01/12 03:24pm Link  |  Print  |  Notify Moderator
Not a water pump got that under the sink,had to change it last year. Looks like air or vacum
barnaclebill
Posted: 07/02/12 04:08am Link  |  Print  |  Notify Moderator
Central vacuum system?
2ndhom
Eugene, Oregon
Posted: 07/02/12 08:29am Link  |  Print  |  Notify Moderator
Disconnect it and see what stops working !!!!
randco
Somewhere in time
Posted: 07/02/12 08:48am Link  |  Print  |  Notify Moderator
What type of line is coming off of it?
Can you trace where the line goes?
Can you disconnect the line at the pump and energize it? With the line off and the pump running you should be able to tell if it is sucking or blowing.
slumberguy
okanagan canada
Posted: 07/02/12 09:36am Link  |  Print  |  Notify Moderator
Vac pump to run cruise and dash hvac controls
MCDDY
Louisiana
Posted: 07/02/12 11:10am Link  |  Print  |  Notify Moderator
Should be a 12V vacuum generator to run the HVAC vents in the dash. Pull the line off of the vac pump and as said find out what doesn't work. I'll almost bet that the Dash AC will default to the defrost position. Been there done that except the pump is on the firewall above the genny slide.
Dave
GEAUX TIGERS
Dave, Miss Sue & Lucy the Scotty
Big Easy Area.
FMCA 153192
2000 Monaco Windsor, 40' 2 Slide, ISC 350 HP.
2012 Honda Pilot or 1998 Blazer Toads
Aventa 2, Brake Buddy
