RV.Net Open Roads Forum: Beginning RVing: disconnect batteries when hooked up?
 > disconnect batteries when hooked up?
lumpy790
York, SC
Posted: 07/01/12 09:53am Link  |  Quote  |  Print  |  Notify Moderator
does the converter monitor and only charge when its needed? Or is it charging all the time?
Tow vehicle E450 Moto Hose Box Van
06 Victory Lane TH
YZ250 Smoker Supermoto
YZ450F
86 TY250 trials bike
1rickw
redwood City, CA USA
Posted: 07/01/12 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I know that if I try to disconnect the batteries while plugged in with the disconnect switch and the refrig in on, they won't disconnect. The frig needs the 12volt even though it is on AC.
2004 Jamboree 26Q + great wife to travel with
mowermech
Billings, MT
Posted: 07/01/12 10:35am Link  |  Quote  |  Print  |  Notify Moderator
ffpm wrote:
Do you disconnect the batteries when you have full hookups?
No, I never do. The Southwind is sitting in the driveway now, plugged in.
We full-timed in a 1977 Pace Arrow Class A, a 1988 Suncrest Class A, and a 1999 fifth wheel. Never disconnected the batteries in any of them while on shore power. We spent 13 to 26 weeks continuously plugged in. No troubles.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
SCVJeff
Santa Clarita, CA.
Posted: 07/01/12 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
K3WE wrote:
CRAMD wrote:
There is absolutely no reason to disconnect your batteries when you have full hookups.
Absolute statements are almost always wrong.
Not all campers have the latest in fancy converters and- if connected continuously- will over charge, "boil the batteries" and damage them. (Just as Vintage says.)
So, someone, hooked up for an extended time period, may have a valid reason to dissconnect the batteries.
Also, a lot of folks have an extremely handy switch so that the batteries can be disconnected with the flip of a switch.
One can certainly nit-pic these statements, but the bottom line is that most, if not all of these "vintage" converter/ chargers have extremely poor regulation and can easily drift north of 18V with no load (ie- My Pace did). Anyone having one of these old converter/ chargers needs to keep the batteries hooked up, and full of water, and watch them. Or invest in something like an IOTA float charger.
PS- The switch is there simply as a storage function.
Jeff - WA6EQU
Chuck&Gail
In the Colorado Mountains
Posted: 07/01/12 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
No
In fact older converters (in my 2003 Thor for example) warned to NEVER connect shore power with battery disconnected as doing so could easily damage fridge and water heater control boards.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
BillyGo
Posted: 07/01/12 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
No need
2011 Forest River Berkshire 360FWS
2012 Smart car for two
ReadyToGo
Minnesota
Posted: 07/02/12 07:25am Link  |  Quote  |  Print  |  Notify Moderator
There are three things that used to require the battery. I believe that is still true.
The furnace uses it for the fan.
The little distance switch for the antenna.
The Refrigerator to start.
On any unit you can check these out if you unhook the battery and see if they still work.
SCVJeff
Santa Clarita, CA.
Posted: 07/02/12 10:49am Link  |  Quote  |  Print  |  Notify Moderator
The furnace uses it for the fan.And the LP solenoid
The little distance switch for the antenna.A "distance" switch would imply an attenuator. Whats there is an amplifier
The Refrigerator to start.Not just to start, but the entire control board, including the LP valve
On any unit you can check these out if you unhook the battery and see if they still work.That's a really good way to kill appliances. They will work until they don't because something will have burned up.
Unless I missed a reply from the OP, he simply asked if he should unhook the batteries? Nobody has any more information than that on what make, model, year, and even why he asked? You can NOT just arbitrarily start removing batteries, run the converter/ charger alone and assume that everything will be fine. The newer, hi-end float chargers are usually regulated, MOST of the standard issue older chargers are not, and we have no idea what he has.
So the absolute answer is that NO, you cannot just unhook the batteries without a chance of damaging something.
* This post was edited 07/02/12 11:02am by SCVJeff *
mlts22
Austin, Texas
Posted: 07/02/12 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Batteries take so long to charge when on generator that without a solar kit, it would be crazy not to take advantage of usable juice. Even with a battery-boiler like my Parallax Power 7155, I always keep my batteries hooked up.
Unhooking batteries as stated above isn't a good idea -- they act as a "buffer" so devices can obtain a reasonably stable voltage without too many sags or spikes.
Bit Bucket
Brookings, Oregon
Posted: 07/02/12 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious, why do your batteries take longer on the generator?
Is that vs chore power or vs something else?
