RV.Net Open Roads Forum: Class A Motorhomes: TV Sound
 > TV Sound
PortAdoug
Posted: 07/01/12 08:20am Link  |  Quote  |  Print  |  Notify Moderator
My front tv, has no video out plugs, hence when going down road, sound is from tv only and famlly cannot hear...is there a way to add a speaker, I do have Direct TV with in motion sat dis...
pkunk
Questa, NM
Posted: 07/01/12 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I'm surprised the TV works going down the road. Most are disabled when the ignition is on. It is illegal to have a distracting TV where the driver can possibly see it.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
rk911
Wheaton IL
Posted: 07/01/12 08:33am Link  |  Quote  |  Print  |  Notify Moderator
in most cases the audio out jack on the rear of the set is *un*-amplified so you'll need to amplify the audio. i currently have the audio output connected to the overhead speakers and that works just OK. but that amp recently blew (for the second time in 4-years) so i'm looking into adding a 'sound bar' to the front TV. a sound bar is just what it sounds like...an amplified speaker. visit a local electronics store and ask about it.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
sch911
Rochester Hills, MI
Posted: 07/01/12 08:35am Link  |  Quote  |  Print  |  Notify Moderator
X 2 Generally easy to bypass. Is illegal, and while not common there have been posts about people getting cited for this over the years.
So for the sound question, is there a headphone jack on the TV somewhere? What make/model TV is it?
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
PortAdoug
Posted: 07/01/12 08:36am Link  |  Quote  |  Print  |  Notify Moderator
tv cannot be seen by driver, which is why have in motion sat hookup for guests...
barlow46
Edgewater, FL
Posted: 07/01/12 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Make and model of TV. Are you talking "video out" or "audio out" or both?
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
daveshan
Durango Colrado
Posted: 07/01/12 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
It's amazing how many TVs now days do not come with any audio out and limited video out features. With the advent of the HDMI plug they're a vanishing feature. I looked long and hard before finding a 32" LED/LCD with a headphone jack for our coach.
That being said are there any RCA type output jacks? The red and white will be audio and there are converters to fit them to a 3.5mm plug you can run to your stereo if it has a front input.
If your TV has only HDMI ports your best bet is a cheap soundbar from WallyWorld or something like that. They're standalone, self amplified things that sit on top of the TV and are "fed" by a HDMI cable. They do require a 120v outlet.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
Diplomat Don
Moorpark, Ca
Posted: 07/01/12 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a home entertainment system, you can sometimes route the TV through the home entertainment system to use those speakers. At minimum, the home entertainment system my have a headphone jack that you can wire to speakers.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
Wherever I happen to park
Posted: 07/01/12 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
YOu said you have DirecTV
I will assume that the "Front" TV is where the driver can not see it, IF this assumption is false then turn the TV off, re-enable the ignition interlock Get a portable TV you can set where the driver can not see it and which has some kind of Audio OUt jack, either headphone or RCA jacks (Red/White, yellow is not needed)
On the back of your DirecTV receiver should be a set of RCA jacks, RED/WHITE/YELLOW.
Route these to teh audio amplifier you wish to use (House radio or the AUX IN on the dash radio) you may need to buy a special cable, or not, depending
Read =- Right, White = Left, channel audio.
ALSO on the rear of the sat receiver should be a little square black plug, if you pull the plug there is a red light behind it.. This is a TOSlink transmitter, If you have a "Home teeater" system then the back of the amplifier has a matching black plug but NO red light.
You run a special TOS/Link fiber optic cable between those two, Way better sound. (in some cases, Dolby 5.1 in my case, if the show is transmitted that way)
Note: In my coach, And I'm sure many others,, The house radio speakers are also used by the dash radio. Now the switch may be done by starting (Or turning to accessory) the vehicle,
Or by turning on the dash radio.. Depending on who wired it.
PortAdoug
Posted: 07/02/12 06:04am Link  |  Quote  |  Print  |  Notify Moderator
thanks guy, the hook up with direct tv box fit right into my stereo system, fixed me, great information, this forum is great...
 > TV Sound
