RV.Net Open Roads Forum: Travel Trailers: Awning foot holders
 > Awning foot holders
dtzackus
Cumbola, PA
Posted: 07/01/12 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Hi, hopefully can someone can give me the correct term I am looking for.
When you open your awning, your poles that come down and actually connect your bottom of you RV, are attached by a certain lath that is screwed into your camper on the bottom.
What are they called, I would like to purchase two and make a holder out of 2 x 6's and put 4 holes in the wood and stake it to the ground, so I can have the awnings arms straight out, instead of having those arms on a 45 degree angle and a little bit of a trip hazzard.
Or if anyone has tried this and can make a recommendation...
Thanks in advance.
Dan, Tammy, Cory, Leah and Adam
2011 Chevy Silverado 2500HD 6.0
2012 Conquest 297DBS
Equal-i-zer Hitch
GM Integrated Trailer Brake Controller
past-MIdirector
Michigan
Posted: 07/01/12 10:30am Link  |  Quote  |  Print  |  Notify Moderator
I've used Awning Arm Anchors about $10 from Camping World for years. They screw into the ground and have bolts with wing nuts to attach the arm to.
Joy
Henderson KY 42420
Posted: 07/01/12 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Maybe I don't undertand your question, but the end of the awning arm (that goes against the trailer into the holder you seem to be describing)can be put on the ground and staked down so the arms is vertical instead of at a 45 degree angle against the TT. To make it more stable, you can attach a strap with a curved metal end that fits over the awning roller at the top and has a ratchet type tightener on the bottom end. The ratchet end is attached to a twist style stake that is "screwed" into the ground. One of these at each end of the awning does the job. There is also a thing called "the Claw". This has 4 opposing "hooks" that dig into the ground whenever any upward stress (like wind) is applied to the awning. An excellent invention! You can probably find it at CW. We have a brand new one - NEVER used - have automatic awning now and can't use it!!! Would sell it cheap to anyone who might be interested.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
johntank
Oxford, Ms 38655 USA
Posted: 07/01/12 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
If your ends are like mine on the awning arms they have a hole on each side, why not just take something like 3/8" rebar and stake them down through these holes on a angle and be done with it.
MitchF150
Washington, the State
Posted: 07/01/12 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 07/07/12 09:58pm by MitchF150 *
K Charles
Connecticut
Posted: 07/01/12 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Like said above just set them on the ground and put a stake in the hole
dyb
s.c.
Posted: 07/01/12 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
I use Tent stakes.
2005 F 250 5.4, 4.10 Gear, Tow/Haul, TorqShift Tranny 8ft. Box
Built in Break Controller
Super Duty super cab 158" wheel base
Eagle 320 rlds 2008
Raised Oct, 1988
Reese Dual Cam
copeland343
Central Louisiana
Posted: 07/01/12 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
To answer your question they are called "Awning lower wall brackets".
JJBIRISH
Butler, PA, USA
Posted: 07/01/12 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
When you put your awning out in the carport position you need to stake the foot as said most just use tent pegs or spikes… but you should always anchor it with good stakes and tie downs… a assortment of stakes for different soils is good to have… I carry the auger type some long and short metal drive in type, and the claw is a good one to carry…
Claw
A&E Hardware kit - 3309676.009#
901019 Bottom Bracket, Carefree 01-0545
Love my mass produced, entry level, built by Lazy American Workers, Hornet
