RV.Net Open Roads Forum: New Dometic 13500 AC only cool down to 71 degrees
 > New Dometic 13500 AC only cool down to 71 degrees
chiefneon
Livingston, TX
Posted: 07/01/12 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy!
We had a Coleman 13500 AC in the bedroom of the 5er we had to replace. The RV repair had a new Dometic 13500 AC in stock so they installed it. This new Dometic AC just like the Coleman is a dump AC with controls in the unit not vented which is not a problem. The problem is the new Dometic placed on the coolest temperature setting and high fan will only cool to 71 degrees and then the compressor kicks off. The temperature rises to about 74 degrees and then the compressor kicks on and starts cooling. In this Texas heat its comfortable coming on and off all night long between 71 to 74 degrees. The RV repair who installed the AC contacted them and Dometic states that the new units do have a cutoff that they will only cool to 70 degrees. I plan on contacting the RV repair on Monday to have them replace the Domectic with a New Coleman unit which they said they would do.
So anyone ever hear of this situation that new AC's only cool to 70 degrees. Hope that a new Coleman does not do the same thing.
"Happy trails"
chiefneon
midnightsadie
ohio
Posted: 07/01/12 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
check the auto kickoff on the coleman before you do the work.
robsouth
Near Atlanta, GA
Posted: 07/01/12 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I could not stay in the camper at 74 much less 71 degrees. That is time to turn on the heat.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
Chris Bryant
DeLand, Florida, USA
Posted: 07/01/12 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
What kind of thermostat are you using? Is this a ducted unit?
The standard air distribution boxes with mechanical thermostats do have a fairly high low temp- but I think they all are around 70.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
rvluversnc93
Thomasville NC
Posted: 07/01/12 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a new dometic and the manual says the max cooling setting is a low of 65 deg and highest temp is 90 Deg. I hope the thing cools below 70!
Happy Camping !!
Derek - FD Battalion Chief
Teresa - Technology Assistant
Hers - 11 Dodge Charger
His - 04.5 Dodge Ram 2500 CTD Q-Cab
(Real Trucks Don't Have SparkPlugs)
2011 Canyon Trail Fiver
Antique Deere
LaGrange, IN USA
Posted: 07/01/12 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Good grief! Below 70 degrees is furnace time. I do not know the characteristics of this new R410 referigerant they are required to use. Perhaps it causes the unit to freeze in temperatures below 70 degrees. If that is the case, all A/C manufacturers have to use it and may have the same problem. Best check before switching.
Bob T
Wrace
Seattle WA
Posted: 07/01/12 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
I really hope that's not true for all the new AC units because I find that completely ridiculous and unacceptable. 70 degrees is way too warm. There is no way in heck this acceptable.
Duck
Miami Lakes, Fl
Posted: 07/02/12 06:02am Link  |  Quote  |  Print  |  Notify Moderator
My mechanic recently had a problem with warranty service at Dometic. They made some ridiculous statement about the heat pump operation that made no sense. When asked to provide documentation they could not do it.
Don
08-FORD F350 PSD
13 Bighorn 3055RL
chiefneon
Livingston, TX
Posted: 07/02/12 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Howdy!
I spoke with the RV repair this morning. Once again they state after talking to Dometic that 70 is the low point due to the new R410 referigerant. They contacted Coleman and Coleman stated their low point was 60 degrees. They ordered us a new Coleman 13500 unit and will replace the Dometic when it arrives. Just so everyone knows the RV repair is "Joel West RV" located in Livingston, Texas near the Escapees. Rick there has gone above and beyond with great customer service for us seeing Dometic issues.
"Happy Trails"
chiefneon
mlts22
Austin, Texas
Posted: 07/02/12 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Dometic digital thermostat, and the lowest it goes is 60 degrees. I wonder if resetting the t-stat might help with this.
Here is a PDF of the thermostat's manual.
