RV.Net Open Roads Forum: Fifth-Wheels: Cleaning awning
 > Cleaning awning
Ken/CherryValley
Cherry Valley, Ca
Posted: 07/01/12 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Just finished cleaning the awning on my 5er. What a pain!!! Started with camping world awning cleaner, wasn't doing the job, ended up using 409 and a long handled brush.
Any better ideas?
Ken & Marlene
'07 Chevy, Duramx/Allison, crew cab, 4x4, long bed, Reese, 3.73, 4" exhaust, K&N Cold Air kit, Super Chips econo program, Turbo Saver, Prodigy, Air Ride air bags, Sirius radio,
'07 Colorado 30CE 5er
Retired & Hate It.
Yeah, Right ! ! !
tvman44
Southwest Louisiana
Posted: 07/01/12 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Solution of bleach, Dawn detergent and water and let sit then rinse off after awhile, if that does not get it all then reapply and rub with a long handle brush then rinse.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Farmer David
Mattoon, ILL.
Posted: 07/01/12 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
I hose the awning off good then I take about a 1/2 cup of bleach in 1/2 gal of water in pump up sprayer and spray it on both sides, then roll up awning for about 10 minutes then unroll and hose off good, usually does the trick
2013 F450 King Ranch CC Long Box
60 Gal RDS Tank
20K B&W OEM Hitch
2013 Lifestyle 37IK
K Charles
Connecticut
Posted: 07/01/12 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Bleach and dish soap in water. Brush it on and let it set then rinse off.
Ken/CherryValley
Cherry Valley, Ca
Posted: 07/01/12 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Hey, thanks for the come backs.
Will give the bleach & dish soap a try next time.
Hope all will have a safe & sane 4th & a BIG "whoooohaaa" to all those serving our Great Country & those of us that have!!!!!!
maniac007
South Carolina
Posted: 07/01/12 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I use Tilex Mold And Mildew remover. Spray it about two feet up on the inside so the underside of the flap gets soaked. Then spray the top side all the way up, roll up awning, scrub the very top that is exposed, unroll and rinse off with a pressure washer. Gets it clean and smells pretty good. Just be careful when using anything with bleach that when you spray it, is when the wind will blow.
02 F350SD 7.3 CC DRW, 06 Cougar 314EFS
hitec
Lower Alabama
Posted: 07/01/12 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Jomax house cleaner, and bleach. Mix according to directions. The Jomax is around $20 a gallon, but it is concentrated and makes 20 gallons of solution. I just washed mine today, and it is the best thing I have found.
carpetride
Mo
Posted: 07/01/12 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on the Tilex Mold and Mildew. Used it on my awnings this spring they cleaned right up.
2011 F-250 6.7 Lariat CC SWB w/16K Superglide
Airlift 5000 bags with on board compressor
2012 Open Range 399BHS
Charlie D.
E. Texas-Orange
Posted: 07/01/12 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhere on the awning may be instructions on what to use and how to clean. Following instructions probably won't c;ean it as well as you like.
That being said, I have a Carefree and it says NOT to use bleach or other alkaline cleaners as it may damage it. I have used bleach and Tilex anyway and does not seem to have hurt it.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
Carolina Cruiser
East TN
Posted: 07/02/12 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Bleach is bad for awnings. Takes the life out of them. Try simple green in a 75/25 concentrate to water mix.Wet awning down, Spray both sides with simple green on a cooler day, run a brush over it, Roll up and let set about 15 minutes.
Unroll and rinse. If you have really bad buildup it may take twice and pure simple green. To help protect the awning use a sponge mop and apply a coat of 303 protectant after the awning is clean and dry.
Albert & Tamara, the dogs Casey & Cody, Living the simple life.
God never said Saved by Grace;kept by performance.
 > Cleaning awning
