evergladesgator
South Florida
Anybody have any experience jacking up their camper off the axles a couple of inches ? What did y'all use to raise it?
thanks
gator
2000 F250 Super Duty 7.3 PSD.
1999 Skyline 2427 Nomad 5th wheel.Rancho 9000s, Prodigy, Me, wife & two spoiled chihuahuas. PeePee aka Penelope(6/97-7/08) & Hannah. New kid Chiquita aka ChiChi.
Cool Canuck
Winnipeg, MB, Canada
The usual method it to "flip the axles". That is to put the axle under the spring rather than on top. You don't actually turn the axle over as it has an arch that has to be up and this requires new spring perches on top.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
fordsooperdooty
You may have to go to a "blacksmith" or Truck Trailer/Chassis shop to have your hangers modified, adjusted and re-welded.
North Trail RV Repair for example is in South Florida.
And this example HERE!
evergladesgator
South Florida
Springs already on top of axles. My truck is too high. Trailer on too much of an angle. Trailer needs to be raised.
laknox
Arizona
evergladesgator wrote: Springs already on top of axles. My truck is too high. Trailer on too much of an angle. Trailer needs to be raised.
Two real ways to do it. First, is to cut off the spring hangers and have new, HEAVY, longer hangers welded to the frame. Adding cross-braces is virtually a requirement when doing this. The second way would be to add an entire sub-frame below the main frame, to raise it as far as needed. There are a number of threads here, some with pictures, of people who have done this.
Lyle
1936 John Deere Model A
SoCalDesertRider
SanDiego, CA, USA
laknox wrote: evergladesgator wrote: Springs already on top of axles. My truck is too high. Trailer on too much of an angle. Trailer needs to be raised.
Lyle Yep, building a sub frame from square or rectangular thick wall tube steel of whatever height is necessary to gain the desired height clearance is the best method to lift a trailer. In his case, it sounds like a simple frame made of 2x2x1/4 square tube with a cross member at each spring hanger location would do the trick just fine.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
nremtp143
Georgia
I posted this back in August of last year after we lifted my buddy's toyhauler and a 5er.
"There are several campers around that have been lifted. My camping buddy has a toyhauler with a sidewinder hitch that was way too close to the bed of truck. He actually hit it on our trip before last. We raised the hitch but it pulled slightly nose high. His springs are 1 5/8" wide. We found a local welding service that had 1 1/2" square solid steel stock. We had them cut 4 pieces 4" long(one to sit atop each axle). We then had the stock drilled for and inserted pins for the pad and a holes drilled to accept the spring bolt. Ordered new(longer and stronger) u-bolts from www.eatonsprings.com for his 3" axles. Went on without any problems and has towed without any problems. Since the spring are 1 5/8" wide and the steel stock is 1 1/2 there is hardly no room for movement. It raised the camper 1 1/2" and now the rig tows level even with the toys in the back. We have re-torqued the bolts a couple of times now and will do it a couple more. I know some people are going to freak out about raising a trailer this way, but there are many others that do it a lot more unsafe methods. This has worked for him. May not work for you. Just something to consider."
You can also use thick walled square tubing and get the same results.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
sheltieRV
cal
evergladesgator wrote: Anybody have any experience jacking up their camper off the axles a couple of inches ? What did y'all use to raise it?
thanks
Take a look at the correct track system from mobile outfitters. You get 2 inches of height and a way to align your rig.
spud57
Stratford PE
This could be an option? It corrects alignment issues AND raises the trailer 2".
http://www.pplmotorhomes.com/parts/rv-wheel-covers/axle-alignment-kits.htm
2008 F250 XLT 4x4 SC LB V10
2010 Outback 321FRL 5th wheel
wfreeth
Guelph, Ontario
thanks
Something like this?
2006 Dodge Ram Megacab Laramie 4X4 Hemi
2004 Four Winds Classic 28BH-M5
Pullrite Superglide 2700/Firestone Ride-Rites
Drive a Hybrid, I need your gas!
