RV.Net Open Roads Forum: Towing: New TT and engine rpm question
Search only in Towing
Open Roads Forum  >  Towing
 > New TT and engine rpm question
bigfish3
Blaine, WA
Posted: 07/01/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I'm hoping to hear from some experienced towing folks. We recently purchased a Keystone Springdale 210BHL. Dry weight listed on decal as 4270. I have HD tranny and engine cooler. GVWR: 6700 Payload: 1450 Base weight Front: 3011 Rear: 2213 GAWR F&R: 3900 GCWR: 11,500 Max Tow: 6100 I am wondering what kind of rpm's I'm going to experience towing this unit with my listed TV. I'd like to get the warm and fuzzy that I'm not going to rev so much my engine goes airbone out the front ot the TV!!
Post moved from TT Forum to Towing Forum
Moderator - TT Forum
* This post was edited 07/01/12 08:13pm by an administrator/moderator *
Mike & Marylyn + our hounds Emmit,Peaches and Bonnie
2012 Dodge Ram 2500 HD Crew Cab 4X4 5.7L Hemi 3.73 Diff
Reese 1500lb SC Hitch w/built-in sway control
2013 Keystone Springdale 210BHL
bigbullelk
Atlanta
Posted: 07/01/12 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Even with a half ton TV (guessing that's what you have) you should be fine. My TT weighs about the same and I tow it w/ a half ton (Tundra). All depends on what kind of elevation you are going up and how hard you like to stomp on the gas pedal.
netaq
Atlanta, GA
Posted: 07/01/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sure it will scream often. I just sold an F-150 with a 4.6 and it would really wind up pulling a 14" v nose utility trailer. Same thing with my current truck & tt. I would not worry about it though; unlike our diesel brethren, high rpms are something the Gasser crowd becomes quickly accustomed to. As long as all the temps are in spec, you're good.
2012 Ford F-250 XLT 6.2 FX4
2012 Keystone Cougar HC321RES
Terryallan
Foothills NC
Posted: 07/01/12 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
Wwith the 3.55, with OD turned off. Mine does 2300 or so RPM at 65 MPH. Right in it's power band, running free, and happy. Will drop a gear, and run near 3000 up some interstate hills. Now IF it will hold OD. The RPM will be closer to 1900.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
old guy
Oregon (pronounced Or e gun)
Posted: 07/01/12 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
with my 4.10's and a 6.0 L engine, I run about 1800 to 2000 rpm's at 62 mph in OD. out of OD I hit around 2500 to 2600 rpm's to maintain 62 mph
Bob Landry
Austin, texas
Posted: 07/02/12 06:58am Link  |  Quote  |  Print  |  Notify Moderator
6100 is not much towing capacity, even for a half ton. By the time you load the trailer ad the truck you will probably be at the truck's capacity. Lock out overdrive and see what you have. You'll probably run higher RPM than most of us driving gassers, but the engine will take it. If the higher RPM is an annoyance, you might consider upgrading to a bigger truck. You'll need it anyway when you upgrade to the bigger trailer. I'm pulling around 8000lbs with a Tundra, but it's a 5.7L and a 4:30 rear end and it pulls all day at 2000 RPM, so there's no shame in towing with a half ton.
2011 Tundra 5.7L
2011 Keystone Outback 277RL
eric james
Sioux Falls, SD
Posted: 07/02/12 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Turn off the overdrive and let it rev. Your next option is to switch to 4.10 gears.
Four speed OD tranny? If it stay in 4th with overdrive off most the time, you're not doing too bad. If it's dropping to 3rd to hold 65, may want to think about those gears.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
jerem0621
Sequatchie, TN
Posted: 07/02/12 08:11am Link  |  Quote  |  Print  |  Notify Moderator
on grades and pulling up to highway speed with short merging ramps you will see 4000-4500 RPM. You will get use to it. The Truck is doing it's thing. Gassers must rev higher than diesels in order to make power.
My V10 pulling a 7000 lb TT will turn 4000-4500 rpm to gain or maintain speed on some steep grades. Don't worry about the RPM, as long as the temps are OK, OD is off, and the O/D light isn't blinking you are OK.
(Ford blinking O/D light means that there is a problem with the tranny, most likely overheated)
Thanks!
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
