RV.Net Open Roads Forum: General RVing Issues: air condition
 > air condition
dessa1930
north carolina
Posted: 07/01/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
how does your air cond work when its 100 degrees outside
mine runs for 3 hours at a time and still only keeps it at 79 degrees inside
it its a 32 ft trailer
gemsworld
Sunny Southern California
Posted: 07/01/12 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Expect your AC to cool the inside no more than 20 to 25 degrees when temps get that high on the outside.
dupreet
High Point, NC
Posted: 07/01/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
X2, and one unit cooling 32' is quite a task.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
robsouth
Near Atlanta, GA
Posted: 07/01/12 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the A/C is working well. Enjoy.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
4huskers
Posted: 07/02/12 05:57am Link  |  Quote  |  Print  |  Notify Moderator
I wish my current unit did as well. Getting a new 5ver with 2 AC in a couple of weeks.
dsurette
Ooltewah, TN
Posted: 07/02/12 06:44am Link  |  Quote  |  Print  |  Notify Moderator
It helps a lot to cut some of that metalized bubble wrap cut to size and put between some windows and the blinds. It usually can be found in Lowes or Home Depot in the insulation aisle. Camping World also has it. It makes a huge difference in our 32 ft "C".
dan-nickie
Grand Prairie, TX
Posted: 07/02/12 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like it is working pretty well.
You have to block the heat sources.
Get some Reflectix to put over the windows on the side facing the sun.
Instant relief.
Dan and Nickie, Four Winds 31p, Retired Jan/2011
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 07/02/12 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I ordered my MH with two 15,000 btu Dometic Penguin(low profile) units,...(ducted).
In, 103 degree weather, parked in my backyard with all shades down, awnings extended and windshield sun shield up, BOTH air conditioners running on max cool is what it takes to be quite comfortable inside(about 73-74 degrees).
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Dixiechick
Trussville, AL
Posted: 07/02/12 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Also put out the awning.
Cathy and Don, finally retired
Cats-Whiskers the Princess and Shadow the Baby
2008 Allegro Class A Open Road 32'
wilcamp
Belmont Co., OH
Posted: 07/02/12 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Let's see, 100 outside, 21 degrees cooler inside. I know which would feel more comfortable for me. Ours sometimes takes an entire day to reach its coolest operating level, in the mid- to low-70s. At times, this includes freezing up after 4-6 hours, a 15-20 minute thawing-out on the high fan setting, then back to the high cool setting.
We had barely reached that comfort level this past Thursday/Friday, when the wind and rain storm blew through the campground in the Hocking Hills area of south central Ohio. Electricity went out about 5 PM, water pressure was gone by 8 PM. (CG operated from a well, it required electric pumps to pressurize the water to each site.) Fortunately, we had 20-30 gallons in the fresh water tank, LP to run the fridge and stove, and two fully charged 12V batteries for the lights and water pump, but NO AC!!!. We stuck it out through the end of our reservation, late Sunday morning, but the heat/humidity factor was oppressive. Having the AC cooling the inside to "only 79 degrees" would have been great!
Wil, Tara, Nakeeta (Alaskan husky 6 yr.-old), and Keeko (Jack Russel/Chihuahua mix 3 yr.-old)
(Joey our 6-yr. old Jack Russel mix, passed over the Rainbow Bridge 12/19/09.)
2008 Jay Flight 24RKS; 2006 Chevy Suburban 1500 4X4 Z71
 > air condition
