RV.Net Open Roads Forum: Tech Issues: self contained portable ac unit
 > self contained portable ac unit
FunnyCamper
Southeastern
Posted: 07/01/12 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
can I use one of these in my master bedroom in my 5th wheel?
I have one AC unit and it is located in the back bunkroom. one vent in front master. need it a bit more cool but don't want to add another AC unit at this time.
Can I use this?
Does anyone use anything like this to cool down a specific area in their camper?
thanks
KuulAire-PACKA45
KuulAire
christopherglenn
a little over an hour from Yosemite
Posted: 07/01/12 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
That is a swamp cooler, it will make things VERY humid. If it is already humid there will be almost no cooling, just more humidity.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
FunnyCamper
Southeastern
Posted: 07/01/12 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
yes
I have been reading on it. I realized that NOW (drat)
the reviews were not fab on it and suggestions to keep it near an open window...etc. etc.
not what I am searching for at all.
I hope there are other suggestions people do use???
edited to say I have been checking the 'real' ac units and they are big. even the small ones are big and have to be vented thru a window.
hmm...not sure if this is a good idea
chevyman2
missouri
Posted: 07/01/12 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
There was a fellow up here in Mo. that had a PUP with some kind of portable A/C unit. He had it vented out the storage door. Though I didnt walk inside his PUP to take a look. I was standing by the door when he opened it, and the air coming from inside was every bit as cold as my PUP was with roof A/C.
Tim-DW(Kathy)
12 Chevy Sonic DD, 03 JEEP GRAND CHEROKEE, 95 Palamino PUP
When I grow up I want to be retired.. THEN I WONT HAVE TO GROW UP AT ALL!!!!
fordsooperdooty
Posted: 07/01/12 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
What you were tlking about was a basic "swamp cooler" that needs a dry/low humidity enviornment in order to work.
This is what you need...
Look here... for a post about "Portable Air Conditioners".
LQuig
Idaho
Posted: 07/01/12 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Try google , there are some that would help
Pepperoni
Ypsilanti, Michigan 48198
Posted: 07/01/12 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
You want a Portable Air Conditioner They vent through a hose to the outside. I would add a round screw-closeable (boat hatch type) port in an inconspicuous place to vent the hose. Some types come with an adjusatable window fitting
1L243
Astoria, Oregon
Posted: 07/02/12 12:08am Link  |  Quote  |  Print  |  Notify Moderator
I ran a portable AC for a while before adding a second roof AC. I vented it through a side vent. The portable was 9 K BTU.
Adding the second roof AC was the way to go for me. TH was pre wired for Second AC so it was not real difficult.
* This post was edited 07/02/12 08:51am by 1L243 *
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
carpetguy2
N.IL
Posted: 07/02/12 04:34am Link  |  Quote  |  Print  |  Notify Moderator
I used one all the time in my TT.Mine is a 13500 btu.It came with a bracket to vent it out a house window.So I fabricated one for my TT.
2007 chevy 3500 ltz CC LB Duramax
2010 Sandpiper 345 RET
2011 Harley Ultra limited
20 ft Searay 190 Seville
FunnyCamper
Southeastern
Posted: 07/02/12 04:52am Link  |  Quote  |  Print  |  Notify Moderator
thanks alot everyone! good info to help me. will check out the links.
I am on the fence tho. put money into portable or just add that money into the second ac now. hmmm...
