Bruce3404
Eugene, OR
With DISH, if I wanted to use DISH in my motorhome, I simply could move the receiver box from house to MH. Is the process as easy with Direct?
Also, will a Direct HD receiver work with a Dish300? Of course, I don't expect to receive HD signals with the old Dish antenna, but I'm hoping I don't have to pick up a Direct antenna and change it out.
2oldman
Wilson Creek WA
yes, don't know.
don/lou
Brandon MB Canada
Yes
& Yes -after you change receiver set up to single round dish/multiswitch -unless it is a swim set up receiver only
Don & Louise
2000 Coachman Catalina 330 MSB /F53
Rear air bags, 4 Koni FSD Shocks & Davis Front TruTrac
2008 Impala- Remco Lube Pump , Blue OX tow bar & Brake Buddy
Winegard roof dish for Bell Expressview HD tv
SL3 HD- TV4RV tripod set up for Direct HD tv
Kenc_AL
Wedowee AL
Direct HD much more complicated than Dish HD to get all satellites.
Direct SD, if pointing at just the one satellite, easier than Dish.
kmbelt
Owensboro,Ky
Have to get a new dish and LNB i believe. I do not think Direct will use a "Dish" dish and vice versa.
2008 GMC Sierra 2500HD Duramax CC 4x4
2010 Puma 259RBSS
don/lou
Brandon MB Canada
kmbelt wrote: Have to get a new dish and LNB i believe. I do not think Direct will use a "Dish" dish and vice versa.
This is wrong info !
They will interchange for SD
The Texan
Cascade or Meridian, Idaho
kmbelt wrote: Have to get a new dish and LNB i believe. I do not think Direct will use a "Dish" dish and vice versa. No new dish needed, they are totally interchangeable between Direct and Dish, when you use legacy LNBs from the 300/500 dish. If you use DishPro or DishPro+ LNBs, then they are NOT compatible.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
kmbelt
Owensboro,Ky
The Texan wrote: kmbelt wrote: Have to get a new dish and LNB i believe. I do not think Direct will use a "Dish" dish and vice versa. No new dish needed, they are totally interchangeable between Direct and Dish, when you use legacy LNBs from the 300/500 dish. If you use DishPro or DishPro+ LNBs, then they are NOT compatible.
That makes sense. I was basing it on the newer DPP equipment. Not the older equipment. You are absolutely correct. The old stuff does work.
dadechil
Georgia
Use this link and Direct Tv will give you 100.00 in credit
discount for you and I
Wherever I happen to park
First advice I give folks is get an RV account with distant network service, That way they don't hassle you.
Now that we have covered that.. A DISH antenna can be used by a Direc TV receiver, or the other way around, however you may need some expensive electroincs to adapt it.
DISH receivers are very smart, and very adaptive.. They figure out what kind of antenna they are hooked to and use it.
DirecTV receivers you have to tell them and they have a much smaller range of antennas they can use.
That said, if you have only one receiver, It should work
Still, I would replace the dish going the direction you are going,, I mean it'snot like they give you a new antenna with a new account.. Oh wait, they do.
