Ron3rd
Upland, CA USA
Beautiful rig! Smart decision.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
retired-tech
flint mi
looks like it has the extra long wheelbase too? that would make it more stable to. i would advise knowing the laws reguarding flatbeds in your area. here in MI it makes it commeercial becouse to many people were abusing the pickup thing. that means all comercial laws apply here just a heads up.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
45Ricochet
North Idaho
Congrats. Really sharp looking truck.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
jbc28
Gadsden, AL
Yep. Its a 176" WB. Non commercial here in AL, thankfully.
06 F350 DRW cab & chassis, CM bed, 4x4, crew cab, Lariat
05 KZ Sportster 37KX2L
NC Hauler
Asheville NC
Great looking truck and welcome to the "world of dually" ...There would be some that would argue with you until THEY were blue in the face that a dually doesn't offer a more stable towing experience than a SRW truck, but "WE" know better now, don't we.....
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
Denny & Jami
Home Base Nebraska
After you go DRW you will never go back What a lot of the tow bodies do is have a cutout like you made and install a plate in the bottom and then box it in to seal the bed back up.
Denny
2000 F350 SC DRW V10 4.30 gears, Banks Cat Back, BrakeSmart, Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Sumitomo tires
jbc28
Gadsden, AL
Denny & Jami wrote: After you go DRW you will never go back  What a lot of the tow bodies do is have a cutout like you made and install a plate in the bottom and then box it in to seal the bed back up.
Denny
I put 3/8 plate across the frame. I still need some sheet metal to box it in. I will probably use the cut out piece to drop back in when the hitch is out.
SoCalDesertRider
SanDiego, CA, USA
jbc28 wrote: Yep. Its a 176" WB. Non commercial here in AL, thankfully. That's a cab/chassis with 60" cab to axle frame length, which is about 4" longer wheelbase length than a '99-up F250/350 crew cab long bed pickup (172" wb). Very nice truck.
I have an F350 cab/chassis regular cab with 84" cab to axle frame length, which is about 7" shorter wheelbase than my F350 crew cab long bed pickup (161" for cab/chassis, versus 168" for pickup).
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
NC Hauler wrote: Great looking truck and welcome to the "world of dually"  ...There would be some that would argue with you until THEY were blue in the face that a dually doesn't offer a more stable towing experience than a SRW truck, but "WE" know better now, don't we.....  Yes we do....
jbc28
Gadsden, AL
SoCalDesertRider wrote: jbc28 wrote: Yep. Its a 176" WB. Non commercial here in AL, thankfully. That's a cab/chassis with 60" cab to axle frame length, which is about 4" longer wheelbase length than a '99-up F250/350 crew cab long bed pickup (172" wb). Very nice truck.
^good info. I like the cab and chassis configuration. I was surprised to see a 9750 lbs RAWR. It does ride stiff, but with the camper it feels very solid.
I may be close on GCWR still, but I will have plenty of RAWR and GVWR.
Question...what psi are you dually guys running in the rear? My door sticker says 65 psi. The tires are factory replacement E range.
FWIW, I bought a 99 F450 crew cab XLT, but the wife had trouble with the manual tranny. It's ride was super stiff unloaded. I missed the Lariat interior too. My F250 was a Lariat and so is the F350...I am spoiled, I guess.
