boonie
Canada
I have an 25 foot 03 Coachmen Cascade and have just purchased some lake property where I will be parking my trailer long term until I finish building a formal cabin. On the lot, I currently have a cistern for fresh water and one for sewer. The problem is that the sewer is at least 50-75 feet from my unit making it impossible to dump when my tanks are full and it is not possible to park the unit closer to the tanks as that is where the cabin is.
I am writing to see if anyone has any suggestions on what I can do as I really don't want to have to dump the holding tanks from the trailer into a bucket then handcart it to the sewage tank. as that is gross!!!! I don't need something that is permanently connected, one that I can only use when needed would be ideal.
2003 Dodge Ram 2500 Quad Cab 4X4 Long Box 5.7 Hemi
2003 Coachmen Cascade 26RBS with a 14' Single Slide
The only practical use for that pistol is to fight your way back to the rifle you should not have dropped in the first place.
dupreet
High Point, NC
What's the slope from your parking spot to the sewer point? If its downhill, you could conceivably trench in a 3" pipe. Another option would be a macarator. You could keep it temporary with a hose on the ground, or trench it in...50-60' is well within range of them.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
RVnRobin
Can't remember being a
If it is down hill from your trailer to the sewage tank, how about 3" ABS laying on the ground or connecting enough stinky slinkies together to make the distance? I know trip hazards and all that, but you could lay something over the top to protect it. The other option is a mascerator (sp) and garden hose to shoot it from your trailer to the sewage tank. One benefit of this is you could shoot it up hill.
OH man... Someone else just beat me to it.
So much to experience, so little time.
352
Oxfofd, Fl
Macerator. I have one I bought new and never used. So much for doo doo running down hill. This will make doo doo run up hill through a 3/4 inch hose.
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters
just a good ole southern redneck country boy
Come visit with us and swim with the Manatees
TexasShadow
Spring Branch, TX USA
we use a macerator pump when we're visiting friends who have a clean out pipe. it works right well.
TexasShadow
Holiday Rambler Endeavor LE/ 3126B Cat
( Sometimes ) BMW K75 on Rear Carrier
Jeep Grand Cherokee Toad
M&G aux brake system
Datastorm 3990
854 watts of solar power
Always remember you're unique, just like everyone else.
JKQ
352 wrote: Macerator. I have one I bought new and never used. So much for doo doo running down hill. This will make doo doo run up hill through a 3/4 inch hose.
x2. Use mine everywhere, money well spent!
2013 CruiserRv Enterra 314 RES TT, 36ft, 3 slides
2013 Ford F250 Crew Cab Power Stroke Diesel 4x4
Reese WD hitch with dual friction control bars
Dometic 3000 KW portable genset
RoyB
King George, VA
Take a look see at one of the FLOJET 18555-000 Waste Water Pump Kit. This runs off 12VDC and connects to your waste water connection. It will pump your waste water through a water hose connection (Use 3/4-inch size).
photo from google images
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
lanerd
Newport, OR
Boonie... I'm really surprised that you didn't think of a macerator immediately. They are spoken about here on rv.net all the time.
There are several different brands, just get the one with the most powerful motor and you should be fine moving that stuff 75 feet through a large garden hose of at least 3/4"....1" is better, but hard to find and more expensive.
Good luck
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
gbopp
The Keystone State
If you have 120v available at your site you can Build Your Own Macerator Pump. Just another option.
boonie
Canada
That's funny....I've never heard of a macerator pump before but it sounds like that is what I am looking for!!!
Unfortunately, it is not uphill but it is completely flat until the tank then there is a up hill run to the mouth so simply stringing together a bunch of hose will not work but that was my first thought.
