RV.Net Open Roads Forum: Fifth-Wheels: excessive chucking need some help
 > excessive chucking need some help
wrongwayrver
canada
Posted: 07/03/12 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
I am having a heck of a time with chucking. I have 2007 gmc 4dr dually and a 2005 couger 30' 5r. The gvrw on the trailer is 10200 pin weight 1740. 1740 is pretty lite for the duallys capability. The trailer sits level on the truck when connected. I put new tires on the rig last year(Load E)up from D, I wanted a better margin or error for safty. I run the pressure at 70psi tire can handle 80, I picked 70 based on the approx load I carry. So after doing alot of reading here and other blogs I am thinking I need to do several things
1. Increase pin weight 2. better shocks on tv 3. nose down 5r 1 to 2 inches. So this brings me to this question, if I slide the hitch one setting closer to the cab will I acheive the same effect as dropping the nose a bit. Or can I add a 40 gallon portable water tank in the bed of the truck ahead of the pin to increase the weight over the rear axcel of the truck. Thoughts??
Thanks
Old-Biscuit
Across the USA
Posted: 07/03/12 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
The 40 gallon tank will probably make the truck feel smoother but doubt if it will do anything for the chucking of trailer.
Need to increase the pin weight of trailer.
Also check the 'play' between king pin and hitch. Excessive play will cause chucking.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
RCMAN46
NorthWest
Posted: 07/03/12 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
How did you determine the pin weight? I would recommend a trip to your local CAT scale and get some real world weights with your system in tow trim. You need axle weights of truck no trailer and each axle weight of truck and trailer in tow trim.
A major cause of chucking is low pin weight and nose high trailers.
Cummins12V98
on the road
Posted: 07/03/12 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
Weigh each of your rv tires. Using the heaviest tire weight look at the tire inflation chart for your tires, add 5 psi to the recomended pressure. I have done this going from E to G tires with good results. Some will say to use max pressure, that is a bunch of ..........
Good luck
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
craig7h
Marion, Iowa
Posted: 07/04/12 03:33am Link  |  Quote  |  Print  |  Notify Moderator
You are better off playing with the fresh water holding tank in the camper. This however depends where it is located, the closer to center rear is the best. The chucking is the after shock of the trailers reaction to road conditions. Yes a 1ton drw will ride like a truck as it is a working truck.
I had server chucking ended up installing a 5th Airbourne pin box. There are a few mfgs. of this style of pin box. They are all made to help reduce the chucking. Once I installed it did help but not 100%.
Craig
06 RAM 3500 diesel power
08 35' Cardinal
MPI_Mallard
McGregor Ontario,St. Cloud Florida
Posted: 07/04/12 07:48am Link  |  Quote  |  Print  |  Notify Moderator
You might want to look into a Trail Air pinbox,i have one and my fiver floats down the road with no chucking.
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
BrokenElbow
Valencia, CA
Posted: 07/04/12 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I'm pretty happy with my MorRyde pin box. no chucking.
2011 Montana 3455, MorRyde pin box, TrailerSaver BD3 air hitch, G614 tires, 2x6volt batts, 2 x Honda 2000i, Rotochoks, 6 pnt Levelup, TST TPMS, Arvika bike rack, Voyager Semi Wireless Rear Cam, Flojet Mascerator, 2008 F350 Lariat 6.4L diesel 4x4 SB CC SRW
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 07/04/12 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I agree. I have had the MorRyde pin box on my last 2 fivers. works great to prevent chucking. I would not adjust your trailer to ride nose down.
ReneeG
Meridian, Idaho
Posted: 07/04/12 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Gotta say we've never had a problem with chucking. We have a TrailerSaver BD3 hitch.
2011 Bighorn 3055RL
2011 F350 SD CC DRW 6.7L Diesel Lariat, Hensley BD3 with Ford Under-Bed Adaptor
Dave & Renee plus (Champ, Molly, and Paris in spirit), Missy, Maggie, and now Mica!
Billieg2
Gone from this forum
Posted: 07/04/12 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I had some chucking and the 5th was about 2" lower in the front. I raised the hitch 2" so the 5th is level and the chucking went away. I suspect the 5th needs to be level or it will chuck.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
