River&Sand
San Diego, CA USA!!!
I see your from SD, Webbs RV in Lakeside usually has the parts in stock. Your Pump is more than likely a PBL FP12, now Graco 260000 pump.
River&Sand
05 Chev Ext.Cab K3500, Dmax/Alli, DRW, Reese Signature 18k, HappiJac, Jordan 2020
05 Lance 920 Truck Camper
06 Weekend Warrior LE3305, 5th Airborne, Dexter E-Z Flex
01 HighJumper SandSprite 3 Dune Buggy
smknf250
San Diego
Thank you! I am at Webb's RV all the time, not sure why I didn't think to already check there but thanks again.
64thunderbolt
Az
Previous owner let mine sit for quite some time. When I got it home the pump would not work and blew the fuse. I took it apart and the gears were as hard as a rock. They had dried out. It's all good now.
Glen
04 Tail gator XT 34' 5th wheel garage model
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" turbo back exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
hunter1
gray,ga,31032
Hey Guy's, I've been all over the forums about the fuel pump problems and I need to know where the fuse would be located for the pump. I've checked the gears and it seems I don't have power to the pump..
06 Fleetwood Gearbox.
Thanks
ranger001@alltel.net
64thunderbolt
Az
mine is in the fuse panel inside the trailer.
hunter1
gray,ga,31032
I checked there but there is no fuse labeled for the fuel station and all the fuses are good..
Any other ideas
lincster
Mesa Az
For Warriors, the fuse is by the shut off switch, the same compartment as where your main plug is at.
There is no label. It will be a 15A or 20A blade fuse. If they are all good, then you have another problem.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
my996duc1
SoCal
Mine blew the fuse last month.... replaced the fuse and it worked.
Went out today and tried it (run it each month) and have went threw 3 fuses.
Found this thread about the gears swelling.
I have never opened a fuel pump or touched one before.
Any good threads or how-to on replacing the pump gears or is it pretty simple ?
_
2007 Coachmen Cross Country 354MBS
2005 LJ Rubicon Sahara
Macs Dad
SoCal
Old post but good info
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24224087/print/true.cfm
my996duc1 wrote: Mine blew the fuse last month.... replaced the fuse and it worked.
_
07 Weekend Warrior SL2805
05 Chevy 2500 HD Crew Cab 6.0/410 Gasser
08 Polaris RZR
06 KX 250F
my996duc1
SoCal
Macs Dad wrote: Old post but good info
_
Awesome, great info !!
I didn't see it mentioned and it may not matter BUT... which side of the gears does a person sand down or does it matter ??
(Gear cover plate side or pump side of the gears)
_
