RV.Net Open Roads Forum: Class A Motorhomes: Which Roadmaster chassis do I have?
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Which Roadmaster chassis do I have?
MSHappyCampers
Columbus, MS
Posted: 07/04/12 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I want to replace the shocks on my 2002 Monaco Windsor 40PBT. Where can I find out which Roadmaster chassis this coach has? I called Monaco tech support and the guy told me it was an 8R chassis, but he seemed a little hesitant so I want to verify this. I want to use the Bilstein Comforter shocks (or think I do). Can anyone tell me what Bilstein part number I would need for this chassis? Thanks!
Joe & Annette
justlou
Northern, Illinois
Posted: 07/04/12 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Windsor came on the RR8S Chassis. You can find your shocks HERE
justlou
2006 Monaco Diplomat
2004 Saturn Vue Toad
wolfe10
Posted: 07/04/12 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Easy-- if you have air bags outboard in front of and behind each wheel, it is the 8R. If looking inside the wheel wells and don't see air bags in front of and in back of the wheel, look further inboard to find two per AXLE in line with the frame rail. Strongly suspect you will find 8 air bags.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
The Texan
Cascade or Meridian, Idaho
Posted: 07/04/12 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Go to the Monacoers forum, that has close to 4000 members with Monaco coaches. You will get the exact answer, from a member who has your model and year coach, that has already done it. Remember tho, there are 2 types of Bilstein shocks for the Roadmaster chassis, the original extra firm ride and the newer comfort ride model.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
grldst
Dallas, GA
Posted: 07/04/12 11:36am Link  |  Quote  |  Print  |  Notify Moderator
It is likely a "R8R".
mmccwill
Arizona
Posted: 07/04/12 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Look at your shocks, & see if they have a pin (stud) on top & an eye on the bottom, or an eye on both top & bottom -- If they have the pin/eye, then Bilstein # for front is 24-186605 , & rear is 24-186612- Bill Willard
zmotorsports
Utah
Posted: 07/04/12 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
The Windsor is on the RR8S chassis. The RR stands for Raised Rail and the number signifies how many air bags, eight in this case. The last letter determines radiator placement. The RR8S has a side mounted radiator vs. the RR8r which is a rear radiator. That should be the only difference and I don't think that even makes a difference for shocks.
For your Windsor there is even one more difference as it is build using the steel semi-monocoque chassis similar to the S-Series on the Dynasty and up except it only has eight bags/shocks vs. 10 on the S-Series.
Mike.
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
2011 Jeep Unlimited Rubicon
