rerod
Iowa
After installing a 4" lift kit, my electric tongue jack wont jack the tongue up high enough to get on the truck ball and be level. I can use heavy concrete blocks on the ground to extend higher but was trying to come up with a lighter method than hauling concrete blocks around.
Can I slide some heavy wall tubing with a stop inside over the electric tongue jack tube? Maybe 6" of insertion. Then just pulls off when not needed?
edited 07/04/12 01:13pm by rerod *
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
Dick_B
Palos Heights, IL USA
a piece of railroad tie or build a box the correct size or a set of 10 lynx blocks
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
wbwood
Mooresville/Troutman, NC area
After the lift kit, did you install bigger wheels and tires? That also will add to your height. With that much a lift, I would imagine your old drawbar would not be at the correct height anymore. Seems like you need to drop it down.
Brian
RVing Illustrated
2010 Keystone Sprinter Select 31BH
2001 Coleman Santa Fe
johntank
Oxford, Ms 38655 USA
Yes, I made a caster for my cargo trailer and the jack leg goes into a piece of black pipe about 2 and 1/2" welded on top of the caster.
husk
Home
I use the orange, 1" high, stacking lifts available in the RV section at Wal-Mart..........they are strong, light, durable...I use them for leveling as well..they stack and lock like lego's..
rerod
Iowa
Dick_B wrote: a piece of railroad tie or build a box the correct size or a set of 10 lynx blocks
Those lynx blocks look like a possibility. I assume they are light weight..
wbwood wrote: After the lift kit, did you install bigger wheels and tires? With that much a lift, I would imagine your old drawbar would not be at the correct height anymore. Seems like you need to drop it down.
Only thing which doesn't work out is the jack height.. Same wheels, just 4" It will come back down after my trip to Colorado. Im going to test it's limits.
johntank wrote: Yes, I made a caster for my cargo trailer and the jack leg goes into a piece of black pipe about 2 and 1/2" welded on top of the caster.
Exactly.. It would need to fit tight or set screws and add maybe 8" with a foot. It would be weaker on side load fully extended if the trailer wasn't level though.
fasteddie
Perrysburg, Oh USA
http://fastwaytrailer.com/flip/
Try this
2008 Toyota Tundra Crewmax 5.7
2012 Jayco White Hawk 31dslb
buzzard616
Medicine Hat, Ab, Canada
Clicky
Stu & Jackie Metcalfe
2000 Salem 27FKSS
2008 Sierra 2500 HD gasser
