boubou64
kingston
there 's a lot of talk on forums about towing 5th wheel With half-ton trucks but it's all over the place. I'm sure I'm Not the only one looking for answers so I thought I'd Start a thread so that we could compare our experiences with such combos.
How many of us towing 5W with 1/2 Ton?
Which TT and TT?
Positive or negative experience with combo unit?
Future plans?
No need to Re-ash the talk about 3/4 and 1 ton requirement.... Looking for the other side of the coin.
http://3dogsandacamper.tumblr.com
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi
Superglide 2700
Timbrens
Cummins12V98
on the road
Get a 3500 Dually!
You are over loaded!
UH......just kiddin!
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
boubou64
kingston
Cummins12V98 wrote: Get a 3500 Dually!
Actually... Need to change my signature and not anle to do it on my phone.
New 5th wheel: Jayco Eagle Superlite HT 23.5
Same truck, will change tires to Michelin 10 ply and add timbrens or airbag. Not sure
Which one yet
Brigitte
texn1995
West Texas
I was gona say that a buddy towes a Jayco HT with a half ton with no problems.
/////Camping or Ridding when the AirForce will let me stay home/////
///////2009 F250--2012 Jayco 31.5 FBHS--2012 FXDWG///////
wfreeth
Guelph, Ontario
I'm kind of towing with a 1/2 ton, but it has 3/4 ton frame, axles and LT tires.
edited 07/04/12 03:46pm by wfreeth *
2006 Dodge Ram Megacab Laramie 4X4 Hemi
2004 Four Winds Classic 28BH-M5
Pullrite Superglide 2700/Firestone Ride-Rites
Drive a Hybrid, I need your gas!
boubou64
kingston
wfreeth wrote: I'm kind of towing with a 1/2 ton, but it has 3/4 ton frame, axles and LT tires.
Just did my first 5 hour drive with it last weekend and figured it rode better with at least 2/3 water in the FW tank.
Why better with water in tank?
Less weight on pin?
Wish I had more payload but stucked with what I've got so hoping that the pin is not much higher than he brochure print.
If I load most of the cargo behind the rear axles will that reduce the pin weight?
Brewurown
Morganton, NC
I had a hemi and it did a lousy job pulling a 28' TT. I got 9 MPG or less and the semi's passed me going over the mountains. Made one trip and came home and traded for a diesel.
Al & Eva
2007.5 2500 Dodge 6.7
2010 Montana Mountaineer 335 RET
Bessie the Bassett (in doggie heaven 4/10/13)
Little Bit the Terrier (in doggie heaven 5/14/12)
Hickory Foothills Good Sam Chapter member
wfreeth
Guelph, Ontario
boubou64 wrote: wfreeth wrote: I'm kind of towing with a 1/2 ton, but it has 3/4 ton frame, axles and LT tires.
Less weight on pin?
My FW tank is in front of the axles.
Devocamper
West Haven CT
I dont think many tow fifth wheels with a 1/2 ton, everytime you hear someone say they are towing a fifth wheel with a 1/2 you always hear the same thngs , I am going to get stronger tires , I am going to add air bags , I am putting bushings to level the truck out and the wife has to ride on the back bumper of the trailer holding 40 gallons of water to keep the pin weight down. I towed with a 3/4 ton and I was close to all my weights then went for the 1 ton and towing with the proper size truck makes it so much better. You can try to tow anything with a half ton and if you have one of those super fords with the eco well thats all you will ever need you could replace a tractor tailer by fords standards. nothing like the right truck for the job.But to answer your question not many use a 1/2 ton to tow a fifth wheel.The pin weights and cargo over load the rear axle and tires.
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
MyakkaTT
Bradenton, Florida
Just tagging along two see the results. Either they have really improved the 1/2 ton trucks or they have really lightened the fiver.. Personally I towed a 25 ft TT with a Dodge 1/2 ton with 5.9.. Then bought our 3/4 ton, what a difference.. Then bought our fiver and feel comfortable. My old Dodge 1/2 ton would never had towed a fiver safely.
I know though they have some light weight units out now but still can't imagine that wieight on my old tow vehicle.
Yes I have seen some 1/2 tons in camp grounds with fivers, the ones I have seen where not light weight and where way over loaded.
To each his own though, but please know the trucks limits and don't put the other vehicles on the road in danger if you are over your vehicle limits. JMHO
2007 McKenzie Starwood SL 31 BHD
2006 Dodge Ram 2500, Quad Cab, 4x4, CTD
My Wife: Dawn
Myself: Scott
Our Dog: Our new Fur Kid, Kylee
Our Photos
Trailer Mods
"Quietly Making Noise"
