RV.Net Open Roads Forum: Can I run two ACs on 30 amps if careful?
 > Can I run two ACs on 30 amps if careful?
howardwheeler
West, Texas
Posted: 07/04/12 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 15000 BTU DuoTherm and a 13500 BTU Coleman. I am going to a campground that only has 30 amp plugs. It's going to be warm. If during the heat of the day I shut everything else off, can I run both ACs?
MrWizard
Traveling
Posted: 07/04/12 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
you might get away with
IF
you start both in the morning one at a time placed on full cold so they never cycle
BUT you are very likely to overheat and damage the end of your power cord adapter and possibly the cord itself
if it gets hot and melts or burns, you may end up with NO power what so ever
or overheat and damage your A/C,s from low voltage and high current
* This post was edited 07/04/12 08:21pm by MrWizard *
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
jauguston
Bellingham, WA
Posted: 07/04/12 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Not likely.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
eHoefler
ozark mountains
Posted: 07/04/12 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
No. The 2 together will pull 34 amps, I have check it with an Amp Probe.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
2oldman
Wilson Creek WA
Posted: 07/04/12 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
And if everyone else is doing the same, you may not even be able to run one.
howardwheeler
West, Texas
Posted: 07/04/12 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Too bad.
trickyvic3
Raymond NH.
Posted: 07/04/12 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I would recommend just running one unit at a time. Front during the day and rear at night. Otherwise your really pushing the limits. We did run both of ours full time last summer and had no problems, but we watched our amp draw like a hawk lol.
past-MIdirector
Michigan
Posted: 07/04/12 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
My Bounder has an EMS that allows you to turn both at the same time but fridge, water heater have to be on propane and no other major appliances on.
RoyB
King George, VA
Posted: 07/04/12 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I am not experienced on the 50AMP shore power plug but there may be away to use adapters and run one air conditioner off the 30AMP service connector and the second air conditioner on the 20AMP service connector. I would imagine all of the 50A pedestals have all three services available...
Maybe someone else can dime in here. I think I read something to this a few posts back...
It may have been someone had run a separate 20AMP circuit connector to the bedroom air condition and just plugged this one into the 20AMP service on the pedestal. All three of those service points on the pedestal should have their own separate circuit breaker...
Might be something to plan for...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
JaneNLee
Las Vegas, Nevada
Posted: 07/04/12 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Best way for me to answer: "It is like trying to suck a whole watermelon thru a soda straw"
It is not going to happen....
Never RV with anyone crazier than you!!
