RV.Net Open Roads Forum: Hot water Heater, not as hot as usual
 > Hot water Heater, not as hot as usual
supercub
Modesto CA
Posted: 07/04/12 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
My hot water is usually so hot you can't keep your hand under the running water. Today, for some reason, it's not that scaulding hot as usual. It's warm-hot, but not, hot hot. I'm running on shore power. Any ideas? Thanks
Brian
Old-Biscuit
Across the USA
Posted: 07/04/12 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
How long between this use and the last time it was used?
How long has it been since you drained/flushed the water heater?
Does it get 'hot,hot' if on propane?
Electric element scaled up?
Heater Bypass valve cracked open?
Faulty 'normal' t-stat?
Loose connection on electric element?
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
supercub
Modesto CA
Posted: 07/04/12 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
It's been about a month since last useage. I did switch over to gas for a couple of hours, and didn't seem to make any difference.
Brian
JudoJeff
Southwick, MA
Posted: 07/05/12 04:33am Link  |  Quote  |  Print  |  Notify Moderator
I'd check the winter bypass valves to see if it's slightly open, mixing the cold into the hot.
K1BE Jeff
Vulneratus Non Victus
"Wounded but not Conquered!"
nelson
Clio,Mi USA
Posted: 07/05/12 06:05am Link  |  Quote  |  Print  |  Notify Moderator
X2 on checking the bypass valve.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
The Beave
Georgetown TX USA
Posted: 07/05/12 06:39am Link  |  Quote  |  Print  |  Notify Moderator
It never hurts to drain and flush the water heater. I'm always amazed how much crud builds up in the thing.
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/05/12 06:45am Link  |  Quote  |  Print  |  Notify Moderator
If you have an outside shower, make sure that the faucet valves are shut off, and not just the shower head valve.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
trickyvic3
Raymond NH.
Posted: 07/05/12 07:14am Link  |  Quote  |  Print  |  Notify Moderator
X-2
I had that happen a couple years ago, and it took me 3 days to figure out it was just because the outside shower had been left on. Even though it was closed at the head.
Vic
Clay L
Sioux Falls, South Dakota
Posted: 07/05/12 09:11am Link  |  Quote  |  Print  |  Notify Moderator
You might want to check the temperature of the water in the tank. It should be be about 140 degrees (unless you have a heater with a mixing valve then it will hotter). You can carefully release some water into a cup from the relief valve to measure it.
In my case the bypass/diverter ball valve had a slight leak which allowed the cold water to mix with the hot water as it came out of the tank.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Blackdiamond
So. Cal
Posted: 07/05/12 10:12am Link  |  Quote  |  Print  |  Notify Moderator
trickyvic3 wrote:
X-2
Vic
X3, same here.
07 Fleetwood Discovery 39S
Flatbed Trailer towing the toys
05 525 EXC
04 LTZ-250
04 TTR 90
03 XR 80
07 KX100
