RV.Net Open Roads Forum: Travel Trailers: Time to "battle" the Fridge
 > Time to "battle" the Fridge
opnspaces
San Diego Ca
Posted: 07/06/12 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
What I was trying to say was it needs a fuse to make it work, and it would be a good idea to make sure there is 12 volts at the fuse holder as a fuse on a dead wire would be pointless.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
chimeraxp
calgary
Posted: 07/06/12 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah i get that, thas well comman sense to do that . But at this point there isnt hot at either end of the fuse .
enblethen
Moses Lake, WA
Posted: 07/06/12 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like an old three way mechanical refer. No voltage to operate.
LP system, Follow instructions on plate. It appears to have a Piezo lighter system. 12 volts DC, Not good to operate on this. Uses up battereies ina hurry.
120 volt, Need to get 120 volts to cord.
I would not try to fix this old unit. You may find one about the same size at an RV salvage yard.
Sounds like it has beeen chopped up to prevent use as it could create real problems.
Make and Model maybe inside the interior of the fridge on plate on door frame.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
chimeraxp
calgary
Posted: 07/06/12 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
ok done lol
Dometic sales corp usa
mod R.M24A
gas is on on atm and back tubes are getting warm .
so we wait and see .
120v seems to need some work at the breaker box , I wasn't interested in using 120v but I might as well have a look while I can.
Which I have contacted a buddy who works with 120v.(not doing that my self lol
* This post was edited 07/06/12 08:42pm by chimeraxp *
chimeraxp
calgary
Posted: 07/06/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Google is my friend , I took the model number and found the install guide .
http://gasrefrigeration.net/dom_techdata/24_77SM.PDF
on page 40 sub 24 the diagram shows the 12v terminal going to battery
which it isn't , not that i'm concerned , I just like to know how things work and make sure everything works.
enblethen
Moses Lake, WA
Posted: 07/07/12 07:54am Link  |  Quote  |  Print  |  Notify Moderator
The manual is a good find for your refer. It should help you get it going. Looks like several areas contain specific information on it and good troubleshooting.
I see it has a "flint" igntion rather than a Peizo.
CavemanCharlie
Storden,MN
Posted: 07/07/12 09:55am Link  |  Quote  |  Print  |  Notify Moderator
chimeraxp wrote:
ok done lol
mod R.M24A
So you got the gas lit, that's great. Like you said now you just have to wait and see. It will take at least 5 hours before you know. Gas Electric fridges are slow. Espically the older ones.
chimeraxp
calgary
Posted: 07/07/12 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I checked it before left for work this morning , cooler inside not alot ,
The "cooling" plate in the upper in side is cool to touch ,
And the lower section of pipes in the back warm to touch but the upper section isnt warm yet ,
Blockage maybe ? Or normal ?
The 120v side of things guess needs work , my guy said it looks like they bypassed the breaker
enblethen
Moses Lake, WA
Posted: 07/07/12 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Blockage!
Small refer, you could take it out and turn it over a few times. If it has hardened then you could be out of luck. Older models need to be level. If ran out of level blockage can be problem to clear.
chimeraxp
calgary
Posted: 07/07/12 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks you sure seem to know your stuff.
What with the ammonia the pda keeps refering too ?
