RV.Net Open Roads Forum: Tow Vehicles: 2003 Dodge 2500 Hemi towing improvement advice
Search only in Tow Vehicles
 > 2003 Dodge 2500 Hemi towing improvement advice
Page of 6
the1adman
Tucson, Az
Posted: 07/05/12 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2003 Dodge Ram 2500 quad cab 4x4 Hemi automatic 3.73. The truck only has 58k miles and well maintained but towing 5500 lbs the truck struggles, on hills it's in 2nd gear and on long steep hills will shift between 1st and 2nd and be down to 35 mph.. I am looking for advice on how to improve the towing performance. I am not looking for buy a diesel truck advice as I had a diesel and much larger trailer but down sized because of economy. I am not usually a fan of programmers or performance chips but do want better towing results. Any advice appreciated.
352
Oxfofd, Fl
Posted: 07/05/12 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
No diesel no significant solution.
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters
just a good ole southern redneck country boy
Come visit with us and swim with the Manatees
Slated4Greatness
Phoenix Arizona
Posted: 07/05/12 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
AFE intake, Magnaflow Exhaust, and see what that does for you. If it isn't enough go with a tuner of choice. An engine is an air pump so the more you get in and out the better it will run.
And if that still doesn't get you up the hilss like you want to go then add a procharger!
2004 WW SLC3505
Flipped axles & Michelin LTX's on 16's.
2006 F350 Tow Boss W/Training wheels
ARP's, Decked blk and heads, BPD EGR & WPmp, Snow MPG Max H20, Strictly RR & Aux Cool lines, 4.30:1 gears, SCT W/ID Tunes, FS bags, 6" Aus Stacks, Train Horns.
Taco
VA
Posted: 07/05/12 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Is your foot to the floor while you are on these hills.
bmanning
Phoenix, AZ
Posted: 07/05/12 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
I don't own a Hemi nor have I ever, but I have to wonder if your truck is running properly if it is struggling that much with 5500lb behind it.
Other members here tow much more than 5500lb with Hemis and I don't recall reading too many posts regarding unsatisfactory performance.
Do you track your mileage? I have to wonder if there's something (clogged cat or fuel filter, overdue for a tune-up) holding your truck back from its full performance.
I track my MPG mainly to watch for a sudden drop in economy which would indicate a component not operating efficiently.
I politely disagree with Slated4; I've been there, done that with intakes, exhausts, chips, tuners, etc. and in my experience they make very little difference and can actually have negative effects (voided warranties, dirty intakes, loss of low-end torque, additional engine noise, etc)
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
djcjc
minooka
Posted: 07/05/12 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Just traded my 2004 ram 2500 4x4 hemi for a 3500 dually diesel mega cab. I was pulling a 29 ft jayco lot heavier than yours I also had the 3.73 rear end. Are you running in tow haul mode if not do so. I got 7.5 mph only reason I moved up was to get more stability and better mileage. Had one hill on the way to Bristol Tn that I couldn't get over 45 with engine at 5000 rpms. Might be time for a tune-up with that wieght you should not be having issues.
the1adman
Tucson, Az
Posted: 07/05/12 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice. The pedal is to the floor although I let up when it shifts into 1st gear cause it will push 6000 rpm. The truck is not in need of any Maintenance it is very well maintained. I do keep track of the mileage every tank gets very consistent 11.5 mpg in town, Freeway 15-16, Towing gets 8-9 mpg. I don't know if it's a gearing problem or what but it feels like 9000 lbs not 5500 lbs.
the1adman
Tucson, Az
Posted: 07/05/12 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
djcjc.... The 2003 only has overdrive off that locks out 5 th gear. I do always tow with OD off
michaelman501
langley
Posted: 07/05/12 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with all the other posts here, you should have absolutely no problem pulling 5500 LB'S......i would reccommend a tune up and switch the gearing in the rear end! That will definately add some pulling power!
the1adman
Tucson, Az
Posted: 07/05/12 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Only problem with switching gears is I have 2 sets being a 4x4 making that very costly, but it does seem more like a gearing problem than a engine power problem. Like I said earlier no tune up needed truck is in tip top shape and runs awsome just doesn't pull very well at all.
Page of 6
