RV.Net Open Roads Forum: Tow Vehicles: 2008 F250 Crew Cab 8 Cylinder Capabilities
Search only in Tow Vehicles
 > 2008 F250 Crew Cab 8 Cylinder Capabilities
WI Bowhunter
Shiocton, WI
Posted: 07/05/12 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
What can you tell me about the tow capacites on the 5.4L v8. I currently have a 5000 HTT. Looking to go to a 9800 pound(loaded), 32 foot travel trailer. I looked for info on this forum, but could not find anything. I know there is info here somewhere...links appreciated!
Here is a link to a truck I am going to look at. F250 CLICKY
Thanks!
Keep the Shiny Side Up!
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
RedRocket204
Colorado Front Range - Got Elk?
Posted: 07/05/12 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Ford 2008 RV & Trailer Towing Guide - pdf
Go to page 18 for conventional towing, 19 for 5th wheel. Of course absolutes off the vehicle would be best.
I love me some land yachting
Desert Captain
Tucson
Posted: 07/05/12 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
I think the 5.4L is one of the most underrated/underestimated medium V-8's out there. It loves to rev, max torque at 3750 and max HP around 5000 and if and when you manage to keep your foot out of it returns some pretty impressive mileage numbers.... but, even in a very nice 3/4 ton like you are looking at, 9800# of trailer is asking a lot of a 300 HP truck. I didn't see a reference to the rear end gear ratio. If it has 4:10's or better it will be doable but I don't think you would enjoy the ride. As always... opinions and YMMV.
Edit: Came across engine specs {while researching another topic}, and have adjusted the max torque and HP rpm's accordingly.
* This post was edited 07/05/12 05:44pm by Desert Captain *
bmanning
Phoenix, AZ
Posted: 07/05/12 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with Desert Captain to a "t"; very good motor & really nice truck overall, but here's hoping it has 4.10s or even 4.30s under it if you are going to tow 9800lb of RV.
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
bpounds
Whittier CA
Posted: 07/05/12 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Same engine I had in an '04 F150. Pulled a 23' TT weighing less than 6k#. It was okay on flat ground with no wind. But that kind of limits your camping areas. No way would I try a 9k# high profile rig with a 5.4L.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Dave&Monica
Ontario
Posted: 07/05/12 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Not because I have one, but the V10 would be a better option if you can find one. The extra 100 ft/lb of torgue would make a big difference.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
NewsW
US
Posted: 07/05/12 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on the cruising speed wanted and the terrain, it might be OK without 4.3s and maybe not even need 4.1s if fuel economy is a consideration.
I have the 2 valve version and it is one of the best engines I have ever had.
FishOnOne
Katy
Posted: 07/05/12 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Agree 100%
tgreening
Ohio
Posted: 07/05/12 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Dave
Because I have one I don't think I'd recommend either. My TT weighed in at 8,500 lbs ready to roll and while it was fine on relatively flat land, once you started to hit some stout hills it became....annoying. People say they love to rev, and they do, that's where they make peak power. The problem for me is I don't like listening to the dang things rev. Listening to a V8 screaming along at 4000+ rpm is not my idea of a relaxing ride. The 5.4 is probably going to be worse. You'd be pulling more weight and giving up cubic inches while doing it.
If you plan to spend the bulk of your time on flat land you might be ok, though I'd still be skeptical of the 5.4 with that much weight.
2008 Ford F-450 "Lil Beasty"
2011 Heartland 3950 "Big Beasty"
1970 DW Made in Japan "Big Bossy"
2005 DD Made in Ohio "Big Pain"
2007 DD Made in Ohio "Lil Pain"
2004 GR Bahzu the dog "Big Sissy"
2010 Weim Mobo the dog "Fast Spaz"
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/05/12 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of the towing performance of the truck is going to depend on whether the truck has 3.73 or 4.10 gears. Both were available from the factory. Both can swapped out for something else, if desired.
4.10's should be enough gear to tow the trailer half way reasonably well, though more gear would certainly be nice. If it has 3.73's you will want to change them. I would change them to 4.56 or 4.88.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
