RV.Net Open Roads Forum: Truck Campers: generator overload?
 > generator overload?
tcflyfisher
surrey
Posted: 07/05/12 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a 1000 watt honda inverter generator to charge my dual batts in my camper, when I plug in the camper the overload light comes on on the generator and it goes into limp mode. My question is could the cause of this be the 60 amp converter in my camper? does a 60 amp converter draw to much power for the generator? The generator works fine on my buddies camper though I don't know how big his converter is.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/05/12 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a 3-way or 2-way fridge, switch it to propane instead of 120vac or 12vdc. Turn off all other lights or appliances, etc.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
jimh425
Western WA
Posted: 07/05/12 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Check to make sure none of your other appliances like hot water heater or frig are on AC or dual mode. A converter should max out at about 600-700 watts.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
wcjeep
Tacoma, Wa
Posted: 07/05/12 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
Convert the commonly used lights to LED. Turn off the extra accessories.
2oldman
Winchester WA
Posted: 07/05/12 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
Although the gen is theoretically capable of about 66 amps, it could be a problem. You can try disconnecting one battery and seeing what happens.
smkettner
Posted: 07/05/12 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
1000va is good for about 40 amps into the battery.
675 watts solar
pianotuna
Regina, SK, Canada
Posted: 07/05/12 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If the batteries are "hungry" the 1000 watt genny will be unequal to the task of charging. You could use it with a 40 amp external charger.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
ticki2
NH
Posted: 07/06/12 05:41am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I agree , the battery charging is about the only thing that will use up that 60a converter . The size of the converter in this instance is not so important , it will only draw what it needs so you apparently have some heavy load on it . For instance my 55a converter with nothing on and fully charged batteries is only drawing 0.24a AC . A frig will draw 2-3a AC . An electric WH or micro might do it . I would check for a dead cell in the batteries .
'68 Avion C-11
'02 GMC DRW D/A
christopherglenn
a little over an hour from Yosemite
Posted: 07/06/12 10:27am Link  |  Quote  |  Print  |  Notify Moderator
60 amps at 15 volts + thermal losses is >1000 watts. Add ANYTHING else and you are in trouble. I douby the converter is putting out the max 60 amps, so the anything else is more likely the problem.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
cleary
Fairbanks, Alaska
Posted: 07/06/12 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Progressive Dynamics PD 9260, 60 amp Converter in our camper. We also have a Tri-Metric Battery Monitor. When our batteries are down to 50 or 60 percent the initial draw is truly 60 amps. At 13.4 volts (PDs specs) that is 804 watts. Assuming that the system is not 100% efficient your right at or over the rated output of an Honda EU 1000, (900 watts). That is probably why your overload light is coming on. We have a Honda EU 2000 and it handles our two batteries OK but sounds like it is working pretty hard. You could charge one battery at a time but that would be pretty inconvenient.
Chuck
2006 F-350, 4X4, Crew Cab, V-10, Torqshift, Dually. 2008 Okanagan 106UDB. Both 4-wheelers and snowmobiles. KL7AY Our website
