RV.Net Open Roads Forum: Fifth-Wheels: I hope I have "FRAMED" this question properly?
 > I hope I have "FRAMED" this question properly?
msredneck84
Southeastern U S (habitually)
Posted: 07/05/12 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Do any of the remaining fifth wheel Mfg's. build their own frames? Carriage built their own (if my memory serves me correctly) but, sadly, they are gone now.
The reason I ask this question, I see a lot of post about frame failure and slide room tracking and mechanism failure. It seems to me some of the big boys in the RV Mfg. end need to address this issue. Looks like the field is wide open for an opportunist.
I know I would look long and hard at a company that had enough forethought to build the most important component of the unit themselves. What say you all?
Drinking out of my saucer!
JR45
Warren/OR/USA
Posted: 07/05/12 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Excel builds there own frames http://www.excelrvs.com/resources/videos
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
98 Honda Accord Toad
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/05/12 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
It wouldn't take much attention to quality to easily surpass the quality of what Lippert produces.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Eycom
32043
Posted: 07/05/12 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at changing to a 5er next year in conjunction with retirement and full timing. I believe DRV (Mobile Suites), NuWa (Hitchhiker) and the aforementioned Excel build their own.
RVn Full-time
fordsooperdooty
Posted: 07/05/12 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Northwood Nash builds their own from scratch....they told me during a tour that they went with Lippert briefly...but were disatisfied with the quality and they weren't heavy enough.
SpaceCraft, Nash, NuWa, Excel, Carriage (used to but gone now!), New Horizon, and a few others DIY frames.
It just isn't cost effective to build their own frames...far cheaper to hand it off to an outside builder. But there are degrees and price lines of Lippert frames...some companies specify their own engineered specs and have the frames built for specific weights and sizes of trailers.
Earl E
Green Valley, AZ
Posted: 07/05/12 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the above replies pretty well cover it. Few still build their own, but I can vouch for Northwood. Our Arctic Fox is built like a tank.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel-for sale now that we are not full-timing
2011 Keystone 23rks Hideout to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
Cummins12V98
on the road
Posted: 07/05/12 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know about Excel but NuWa has Youngs in Chanute KS build their frames and Mobile Suites DRV have Lippert build theirs.
Lippert gets a bad rap but most of the time the problem is the rv mfg specs too light weight of frames and they don't hold up. My MS has two 2x6 and one 2x3 tubes stacked on top of each other and is very strong. I have heard of very few complaints of Lippert/MS frames.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
laknox
Arizona
Posted: 07/05/12 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
While I'm no fan of Lippert, I simply don't see why a company can't spec a frame for Lippert (or another company) to build and reject anything that doesn't meet that spec. I'm talking about size and types of beams, gauge of steel, QUALITY of steel and QUALITY of construction. At the same time, those companies that do use Lippert need to either tell Lippert to shape up, find another company to do the work or do it themselves. It HAS to start with better construction by Lippert and they need to do their =own= analysis of a spec to see if it will work for a specific application. This really isn't rocket science (sorry, ERS), but it is fairly simple engineering. You can bet your last dollar that Lippert knows this, but doesn't call the manufacturers to task for it. The more I think about it, the more I'm tempted to rebuild my current trailer and have someone put a new superstructure on the old frame when the time comes. :-)
Lyle
1936 John Deere Model A
LostinAZ
At Home
Posted: 07/06/12 12:13am Link  |  Quote  |  Print  |  Notify Moderator
I'm wondering if the specs are the issue for the high failure rates reported here for Lippert frames or what seems to me to be the most reported problem with Lippert has been due to poor Lippert frame welds.
The Mad Norsky
Yankton, South Dakota
Posted: 07/06/12 12:23am Link  |  Quote  |  Print  |  Notify Moderator
Just a minor correction to info on Hitchhiker frames.
Yes, MOST are still built by Youngs Welding in Chanute, Kansas.
BUT, there are Hitchhiker II models out there with Lippert frames on them.
Not sure if this is still the case, but the Hitchhiker II series were built in another plant in Chanute, not part of the main facility where the Discover America and Champagne series were built.
And it was those Hitchhiker II's that had the Lippert frames. Do not know if they still use Lippert on these, or went back to Youngs Welding.
The Mad Norsky, Doll, Logan, Korey & Rocky
2011 Ford F350 Power Stroke dually
RV'ing since 1991
We never know where we're going till we get there!
