RV.Net Open Roads Forum: Class A Motorhomes: Onan marquis 7000
Nui
Vancouver
Posted: 07/05/12 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have a Onan marquis 7000 generator? If so, can you tell me what type of oil I need to add? II don't have a user manual and can't find info on the net.
We had a problem when driving and using the gen....every time we turned a corner or hit a bump, it would turn off. I'm hoping it is because we are low on oil.
Thanks!
nui
PapPappy
Wilmington, NC
Posted: 07/05/12 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you have no idea what kind of oil it had, you may want to just have it serviced and get the oil changed. You really don't know if it's "Dino" or Synthetic, and you should keep the same oil in it.
I don't know if it will do any damage, if you were to add some 10W-30 to it, but it might be best to do an oil and filters change....for a bit of piece of mind.
Check/replace the fuel and air filters will be a step in the right direction. How many hours on the unit?
Good luck
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
Corkey05
Washington State
Posted: 07/05/12 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
It does sound like low oil. The generator is designed to shut of if the oil level drops too low. The filler cap has a dip stick on it (if it's like mine) ... easy enough to check.
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
toolman1
Cerritos, CA.
Posted: 07/06/12 08:40am Link  |  Quote  |  Print  |  Notify Moderator
See page 6 for Onan oil recommendations
See ya out there!!
Hooliville member #128
Gary & Lynne.
'04 Dolphin 5320 WH-22 370W Solar
22' Mighty Mover Trailer, 60W. Solar.
Sand Sprite 4. 2.3L EFI sand buggy
'04 Polaris Predator
'84 Jeep CJ.
2011 Black Lab "Lucy" for both of us
mike brez
milford ct
Posted: 07/06/12 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same generator and used 15-40
1994 Pace Arrow 33L,454,P30
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
Mr. Jeff
Edmond, OK
Posted: 07/11/12 12:06am Link  |  Quote  |  Print  |  Notify Moderator
My Marquis 7000 calls for 10W30 for cold weather up through 70*F then changing to 10W40. Its the low oil level switch that's shutting you down.
Jeff, Leslie & 4 wonderful kids
2000 Allegro Bus (37,000 miles)
1994 Fleetwood Southwind (212,000 miles and going strong!)
F-53 Chassis, F-460 (Original and nothing special!)
22' MacGregor, Hobie 16, Sunfishes
