Wrace
Seattle WA
I would like some sort of cover to put in the shower skylight to reflect/block sunlight yet still be easily removable for the once-a-day showers. I'm 6' 4" and use the skylight so I can stand up mostly straight while taking a shower.
I see carefree has this type but I'm a little concerned that the roll is mounted such that it hangs below the skylight and might be a headbanger for me.
http://www.carefreeofcolorado.com/carefr........ction=product&productid=59&categoryid=34
I've read some of the back-posts about using the reflectix bubble insulation for windows and such but I assume this stuff is not thick enough by itself to be just pushed up into the skylight and have it stay there? I'm not concerned about something staying in place while traveling at this point because the trailer is parked in one location for the rest of this year. Maybe take a piece of 4" foam and glue the reflectix to it and then just shove it up in the skylight and hope it stays?
Or what about mounting mirror mount clips at the four corners of the skylight trim piece, and then covering a piece of cardboard with tin foil or reflectix and slip the cardboard into the mirror clips each night after the shower?
What do you think?
Also, is it possible to buy this reflectix in smaller quantities than the 4'x25' rolls at homedepot?
Thanks
path1
seattle
Why not paint the top of skylight with cheap black waterpaint then if you don't like it hose it off. If you do like it use some good paint on it.
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
swebber
Brunswick , MD
Wrace wrote: Also, is it possible to buy this reflectix in smaller quantities than the 4'x25' rolls at homedepot?
Thanks
Camping World carries smaller rolls, albeit at a higher price. If you are looking for a piece just to cover your skylight, head to the Auto section of any WalMart or head to AutoZone, PepBoys, etc... and look at the winshield covers. they are also made of Reflectix.
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
Beverley&Ken
Tottenham,Ontario
How about using heavy duty velcro around the edges to hold the reflectix in place.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Ron3rd
Upland, CA USA
Beverley&Ken wrote: How about using heavy duty velcro around the edges to hold the reflectix in place.
Beverley and Ken
That's what we did.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
sheltonlp
Washington State
I had a panel made out of boat top material and use velcro to secure it...works great.
2012 Evergreen Everlite 32RBK-DS
2011 Toyota Tundra 5.7 Rock Warrior
JohnandCara2
Evergreen CO.
We had same problem so I cut a piece of foam board used for posters in the shape of the dome , Then first used velcro later changed to removing the screws and putting washers to hold in place.
1fastdad
mo.
Iuse a peice of 3" foam rubber cut to fit tight on the hole.
dogwood36322
Southeast USA
I took down the inside lexan panel and put tin foil between the ouside and inside panels. Cuts out the heat and the light since our shower is not seperated from the bedroom.
Jim,
Retired US Army, Still training Army pilots at Ft. Rucker, Al.
2011 Ford F350 DRW, 6.7, B&W turnover hitch/5th wheel.
2008 Sandpiper 285RGD
Wally Walleye
Shohola Pa
Use 2 tension spring curtain rods and a piece of material hemmed on both ends. Easy in easy out. You can use a light colored material to allow filter light in or a darker material to block out light and heat. Washable and cheap. Get rods at Wallymart
