sljkansas
Miami Co. Kansas
Our local Tru-Value carries the refectix, that you can buy by the foot.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter can now be called a Teacher.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
pigman1
Delaware
1fastdad wrote: Iuse a peice of 3" foam rubber cut to fit tight on the hole. Yep, and DW covered it with a semi waterproof material. Since we go to Alaska a lot, it works great in the land of the midnight sun. Also super in very cold weather, +15 or so, to help keep the inside warm.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Street Atlas USA Plus
MALE*RN*777
Western MD, USA
We have a couple of those extension rods to hang towels. What I do is to take the towel and hang it from on extension rod to the the shower rod which blocks the sun light. Cost is an extention rod which is used and can be removed without defacing the camper.
03 Ford F150 XLT
Good-bye old friend --- 01 Coleman Sante Fe Pop-up
Hello new friend --- 09 KZ Coyote 23CR Hybrid
Me ,The Wife ,The Boy ,Girl 1 ,Girl 2
We are Blessed.
ralphnjoann
Canon City, CO
Here are some options:
Vent Cushion
Reflective Cover
White Vent Cover
Wiscampsin
Wisconsin USA
DW cut a piece of insulated drapery backing she had and velcroed it in place. Works well as it still lets in light but blocks the heat.
2013 Palomino Sabre 34 REQS-6
http://s1340.beta.photobucket.com/user/W........6?&_suid=1357224714962013706578115184365
mikestock
Vestavia Hills, AL, USA
If you are OK with blocking the light permanently, those skylights (at least mine) are in two layers. The thing allowed sunshine into the bedroom too early in the morning. I removed the bottom layer and installed a black plastic liner between the layers. The plastic I used was thin and it still allows a small amount of light through. If you want to totally block it you could use an aluminum foil liner.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
dennis1949
Decatur, Alabama
I cut 2" styrofoam insulation to fit in the skylight. Helded it in place with velcro srips. it blocked the light and insulated the sky light. worked great
Dennis Carpenter
Decatur Alabama
2012 GMC 3/4 ton Z71 Diesel
2012 Forest River Blue Ridge 3125
Dixon Mark
I had a canvas shop come by and measure the sky lights and made some heavy duty covers that snap into place.
westend
all over
Another one: Cut a piece of this Plas-Tex 1/8" larger than both dimensions and push into place. You may want to attach a tab of tape, cloth, etc. for easy removal.
In fact, I have 35 sq. ft. of it. If you contact me through PM and can relay the size of your skylight opening, I'll cut the piece and send it along. That's all I can do for you, today, lol.
'03 F-250 4x4 CC
Wrace
Seattle WA
Thanks for the replies. I am going to pick up the 14x14 cushions from CW on the way down to the trailer this week for the three vents in the tt. Probably cut a sheet of the refectix to go on top of the pillow and shove it up into the vent.
CW doesn't show a pillow available for the skylight, and I don't remember what size those skylights are?
3" foam rubber 3" x 24" x 80" is $40 on ebay. I do have some foam around here but its real low density and would not likely stay in place at all.
