RV.Net Open Roads Forum: Hybrid Travel Trailers: Hot water heater ? 2 part
Open Roads Forum  >  Hybrid Travel Trailers
 > Hot water heater ? 2 part
outdoordb
Maryland
Posted: 07/06/12 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Should I leave my propane hot water heater on all the time when camping or turn it on as needed. We have always turned it on about 1/2 hour before showers and than turned it off after.But sometimes we forget and have to wait. It seems to run a long time to come up to temp. Is it more efficient to just leavce it on all day and kick on and off as needed to keep up to temp? I am talking full hookup summer camping. Part 2 I see where you can buy an after market electric heating element ( Hot Rod ) anyone ever use these ? Good, Bad ? Thanks
Mandalay Parr
Phoenix, AZ
Posted: 07/06/12 04:53am Link  |  Quote  |  Print  |  Notify Moderator
Mine is ON all the time.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
gbopp
The Keystone State
Posted: 07/06/12 05:05am Link  |  Quote  |  Print  |  Notify Moderator
I don't know if it's more efficient to leave it on all the time or only when it's needed.
I only turn mine on when I'll be using hot water, showers, washing dishes, etc..
The water stays warm enough for hand washing.
JMO
mbopp
Henrietta, NY, USA
Posted: 07/06/12 05:39am Link  |  Quote  |  Print  |  Notify Moderator
Ours is on during the day but off at night.
If you have a Suburban water heater, using a Hot Rod requires that you remove the anode rod. This will lead to accelerated corrosion and failure of the water tank.
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
pianotuna
Regina, SK, Canada
Posted: 07/06/12 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
It is definitely cheaper to turn on as needed rather than letting it run. The heat loss is such that they will cycle about every four hours even if no water has been used.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Lantley
Ellicott City, Maryland
Posted: 07/06/12 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Hot water heater has a thermostat. It will turn itself on and off so you don't have to.....just like at home! Turn it on and forget about it!
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
drenjoey
Gray, Maine
Posted: 07/06/12 06:43am Link  |  Quote  |  Print  |  Notify Moderator
X2............Do you turn it on and off at home! Same in your HTT.
Mine is always on and hot water is available at all time.
C.B.
APPLETON WI USA
Posted: 07/06/12 07:06am Link  |  Quote  |  Print  |  Notify Moderator
X3..........
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~
CB Family Fleet
Butch&Barb 13CedarCreek~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 11 Laredo
wmoses
Houston, Texas, USA
Posted: 07/06/12 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I leave ours on from the time I hook up and the hot water tank is filled to the time we leave. It uses very little propane and I could not be bothered turning it on every time I need hot water. False economy in my opinion.
I am interested in hearing what actual users of Hott Rod systems say about their actual experiences as I considered installing one of these at one point, but seem to recall that it could somehow be harmful (don't recall why).
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
wmoses
Houston, Texas, USA
Posted: 07/06/12 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Ahhhhh .... That is what I had read before as the downside of using the Hott Rod. Thanks.
