When i put transmission n reverse it doesnt always go n if i go to drive n back then it will engage. also when backing it feels like i have foot on break n have to really gunn it to move back . once. i was barely moving back n it felt like it locked up or hit something. i checked n i didnt. . had to really gun it to move.
i was n pkg lot with slight grade n drive n let it slightly drift n drive n put n neutral to see if pkg break was hanging no it wasnt.
soalso a couple time n reverse on my dash in red it say. auto park.. like when i put ot n park.
someone said my 97 chevyallegro bay has a trans that when u put it n park it locks up everything. so trans has solonoid bad telling. it its n park not reverse. or parking modulator.
im n gillete wyo. n its friday on a holiday wkend?
If i drive n drive will i b. ok? Any suggestions?
Oh been having jacks tell me when i try to turn on. Park not engaged. i have to go n out park n redo pkg break. finally i can turn on jacks w/o error light.
This old gramma needs help have to go to rapid city s.d monday 125. miles.
35' 1997 Allegro Bay - No Toad Yet
"We'll be friends until I'm old and senile, then we'll be new friends."
I would troubleshoot the entire shifting mechanism of your transmission, at the transmission itself. It doesn't sound like it is going completely out of park and completely into reverse.
Think you need a Chevy or GM truck shop to check things out. Reason I say Chevy or GM truck shop is because they might have parts in stock. Anyone else would not have parts that may need replacing in stock which would delay your repair. I had a similiar problem and it ended up being the cable that went down thru the steering column to the transmission linkage. The truck shop I took it to had to order that and it took several days to get it. They were not a Chevy/GM garage. I had the problem happen while I was on the road and had a mechanic manually put the transmission in drive. The starter would engage and start the motorhome, but I had to be careful where I parked, cause I could only go forward. That was done about a 1000 miles from home, and I finished the trip that way.
Which trans do you have? Is this an Allison or a 4L80/85E?
If we are to assume this is a 4L80E, I'm thinking the level on the side of the trans may have come loose. There is a nut that holds it in place. If it partially slips of the keyed shaft, it could be very sloppy. Or it could be the cable end as well.
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag? MISC photos Revconeers Forum
