RV.Net Open Roads Forum: Tow Vehicles: Dodge Ram A/C Stopped Working
Search only in Tow Vehicles
 > Dodge Ram A/C Stopped Working
Page of 6
bmet2000
North Carolina
Posted: 07/18/12 08:37am Link  |  Quote  |  Print  |  Notify Moderator
7/18 Update: My local service (not Dodge) station replaced the compressor with a Dodge part because they had the best price. It was supposed to be about $450 installed. But now the signal is not working, it gets 12V and then cuts off. He said it was the Integrated Power Module ($900). Does that sound about right?
2010 Jayco 324BHDS
2012 6.7L Ram CrewCab Laramie Longbed, Manual Transmission, Black , Propride 3P Hitch
Sold 2006 Dodge Ram MegaCab
NewsW
US
Posted: 07/18/12 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you shouldn't worry.
Eventually, he will replace the wheels and tires after replacing everything else, and he will get it right.
My immediate question is whether the analysis was botched and the problem was the TCM all along?
I don't know Chryslers (swore off that problem with the last Chrysler), but someone said the electronic fuse in it can be reset 3 times before you have to replace the box.
I don't have a good feeling about the first work done..
* This post was edited 07/18/12 01:28pm by NewsW *
bmet2000
North Carolina
Posted: 07/27/12 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
'nother update 7/27: My AC SUCKS! It is supposedly fixed but my thermeter is showing 60 degrees in stead of 40 like it always did. Of course I was told that it can't get that low with it being 100 here. Looks like I will be headed to a dealership...
dodge guy
Bartlett IL
Posted: 07/27/12 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
100 deg. Weather should be mo problem getting down to at least 50 on recirculate. I'm guessing they didn't charge it fully.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
NewsW
US
Posted: 07/27/12 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't life be simpler if they just replaced the AC.
bmet2000
North Carolina
Posted: 07/27/12 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
They put the compressor on it, a reman from Dodge. Then they put another one from Dodge. The charge seems good, but I think it is pulling in warm air from somewhere or the blower door thingy is bad again.
Jarlaxle
New England
Posted: 07/28/12 04:32am Link  |  Quote  |  Print  |  Notify Moderator
That is, unfortunately, not an uncommon problem. 5-minute test: bypass the heater core and try the A/C. If it blows cold, you have found the problem.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
NewsW
US
Posted: 07/28/12 06:30am Link  |  Quote  |  Print  |  Notify Moderator
It'd be a lot simpler if you paid for diagnostics rather than have them try everything in order of their preference!
Hannibal
Gas Station
Posted: 07/28/12 06:35am Link  |  Quote  |  Print  |  Notify Moderator
That's what I did with my bride's Durango. But since everything is kind of packed in there, I just installed a 3/4" brass shut off valve in the inlet hose to the heater core just outside the firewall. Turned out it was the blend door and the problem was already fixed with the valve.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
'07 KZ Jag 28JFSS.
Jarlaxle
New England
Posted: 07/28/12 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Stop trolling, kid.
Page of 6
