RV.Net Open Roads Forum: Wiring lighter sockets with 10/2 low voltage landscape wire.
 > Wiring lighter sockets with 10/2 low voltage landscape wire.
Minor Threat
Orange County, CA USA
Posted: 07/06/12 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
I bought some Seadog 12v power sockets for my tent trailer and want to wire them up safely AND economically. I've read about fire conditions when running an inverter for long periods but I plan on only charging and powering USB devices. Is this type of 10/2 cable sufficient for 3 outlets?
http://www.wireandsupply.com/product_p/col-55272.htm
What amp in-line fuse would be the best protection in case somebody did plug in a high draw item? Is that determined by the wires rating?
Thanks for any assistance.
"Friendship is like pissing your pants. Everyone can see it, but only you can feel its true warmth."
Gene&Ginny
North Kingstown, RI
Posted: 07/06/12 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Clickable link
#10 is heavy enough for 30 amp but the fuse should be rated no more than the amp rating of the socket or the connecting lugs. With stranded wire you have to be carefull that ALL the strands are inside a crimp lug.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
camperpaul
Wherever I park my travel trailer
Posted: 07/06/12 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I checked the specs on that wire and it is copper and therefore good for the application.
A lot of the "Landscape wire" is made of steel and not suitable.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
YC 1
Yuba City Calif.
Posted: 07/06/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Most outlets we use in our business are rated at 15 amps which is plenty for usb type charging devices. That wire is fine for the purpose. I use it for my solar panels.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
smkettner
Posted: 07/06/12 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Do you need 250' With just 60C insulation don't go any bigger than 30a fuse.
I recommend some actual wire made for this pupose.
10/2 boat wire 25' $26.25 shipped
For a short piece you can have 8/2 for $1.77 per foot shipped and just get what you need.
This stuff has 105C insulation so you can fuse it like normal primary wire.
* This post was edited 07/06/12 07:56pm by smkettner *
675 watts solar
Minor Threat
Posted: 07/06/12 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input folks. The sockets are rated at 24V, 16A, max. Each one should have its own feed and fuse I would imagine. Is 15A too much fuse if max rating is 16A?
smkettner
Posted: 07/06/12 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
15 amp fuse is fine.
NORM WADDELL
PENSACOLA FL 32514
Posted: 07/07/12 05:35am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure about what wire is being discussed.....but.....
wire has INSULATION covering it...the insulation is rated
for voltage........most common wire insulation is rated
for 600 volts, and is used in 'house wiring' where the
maximum voltage between two adjacent wires is about 320
volts (115 volts x 1.4 for peak x 2 for adjacent wiring
at opposite polarity at any instant).....SOME wiring,
such as thermocouple wiring has VERY LOW voltage rating.
I have seen thermocouple wire, newly attached to a wall,
burn like fireworks when first energized to supply
a refrigerator at 120 volts. Be sure your
insulation is properly rated.
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
Gene&Ginny
North Kingstown, RI
Posted: 07/07/12 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Yup
