RV.Net Open Roads Forum: Tech Issues: Sealand toilet rebuild kit or replace?
 > Sealand toilet rebuild kit or replace?
redsox888
vermont
Posted: 07/07/12 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Is there a rebuild kit for sealand 910 series toilet or do I have to buy an entire new toilet, (ouch). Any guidance, insight and wisdom is hugely appreciated!
Thank you
Newbie to the RV camping world. Just purchased 1990 camper in great condition but toilet needs help
past-MIdirector
Michigan
Posted: 07/07/12 07:12am Link  |  Quote  |  Print  |  Notify Moderator
You might find the price of parts almost as much as replacing depending on what parts you need and if they're available. Campingh World has new toilets starting as low as $149.
Ivylog
Blairsville, Ga. USA
Posted: 07/07/12 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Had a guy at a RV rental place say it's cheaper to replace if you are talking about the moving ball valve. If it's just the bottom seal, then replacing is easy enough.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
pulsar
Lewisville, NC
Posted: 07/07/12 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
Cool Canuck
Winnipeg, MB, Canada
Posted: 07/07/12 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Did one a couple of years ago. Kit cost around $35.00 then.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
docj
Fulltime--Home is where we park it
Posted: 07/07/12 09:52am Link  |  Quote  |  Print  |  Notify Moderator
We replaced the seal last year and found that after a year the bowl wasn't holding water again. The problem is that the ball valve can get scratched which ends up ruining the seal. As someone already noted, the cost of the ball valve plus seal is almost the cost of a new unit. We ended up replacing our toilet last month for exactly this reason.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
rv2go
Fulltime (Knoxville, TN).... or someplace else
Posted: 07/07/12 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
The cost of the Ball kit and the seal are about $45 each. Maybe $100 plus with shipping and Tax. My Sealand costs $244.99 today at CW.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
Old-Biscuit
Across the USA
Posted: 07/07/12 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
RV Toilet Parts
Select 'Toilets' from category drop down window
Select 'Sealand' from menu on left side
Select your model of Sealand toilet
Check for price/availability of repair parts.
Toilet Replacement Comparison Chart
Check for replacement toilet.
Do 'goggle' search for pricing/availability of replacement toilet
Compare repair parts vs toilet replacement pricing.
Your choice........
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
