RV.Net Open Roads Forum: Camping World Service and Installation: A/C unit
Search only in Camping World Service and Inst...
kpconnell
Seattle, WA
Posted: 07/07/12 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
You can run two A/C units with 30A. A 12K and a 15K.
christopherglenn
a little over an hour from Yosemite
Posted: 07/07/12 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
A 30 amp WILL run 2 ac's, and about NOTHING else. Maybe the tv, if you are lucky the ac side of the fridge, you may have to burn propane to keep the power on. If I were ot do it, I would run a dedicated 20 amp power inlet for the second AC.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Us out West
Let's see...last night we stayed in......
Posted: 07/07/12 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
Spreecandy wrote:
Is it normal for a 2013 Forest River fifth wheel air conditioner to not keep up with 104 degree outdoor temp . We have a 32 ft three slides fifth wheel with a 15,000 btu ducted A/C.
Did you buy from Camping World?
Our Trip Journal
2012 Jayco Pinnacle (View)
36KitchenPantryTripleSlide
MorRyde pin box and suspension
Curt Q24
Dual Pane windows
Auto Levelers
2 AC's
And more...
2009 Silverado 3500HD 4X4 (View)
CC,
Dura-Max 6.6/Allison
LB
DRW
American Tank 65 gal. Aux Fuel
B.O. Plenty
Minnesota
Posted: 07/10/12 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Not all Forest River units are of the same quality. The more you spend the better the insulation factors. In general most will not get cold enough without a second A/C unit.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
kpconnell
Seattle, WA
Posted: 07/10/12 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
on my rig its 26amps.. leaving 4. or 440 watts. ten laptops. plenty for us.
although the extra circuit is not a bad idea as a lot of camps have a 20 sitting there on another breaker.
Skylark
Western NC
Posted: 07/22/12 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I do have 50 amp service and the 15,000 btu unit pulls a max of 17 amps on line one but when running goes down to 6 to 8 amps and the 13.5 btu rear unit pulls 12 amps max. I have been able to run both on 30 amp connection but with nothing else on. Sky
kpconnell
Seattle, WA
Posted: 07/23/12 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I am still perplexed by people who say 30Amps just won't do with 2 A/C units. We have been running ours in the midwest heat wave for a couple of weeks now, we have enough spare to run our inverter/charger at 20-30amps (12V), refer, lights, and a half dozen accessories e.g. laptops, cell phone chargers, etc. Ya, the controller will shed occasionally, but overall things are fine. We turn off the rear AC to run the microwave or hair dryer, but other than that, all is well (and we are monitoring voltage, staying above 105v the whole time.)
kckettridge
Northern California
Posted: 07/24/12 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
therink wrote:
One thing I forgot to mention, if you already haven't checked this: make sure that the foil tape in the ceiling vents is providing a good seal around the opening so that precious cooled air is not entering the attic space. It is alsoa good idea to remove the inside cover (4 screws) and make sure the foil tape is neat and providing good seal in there as well. Redoing the crappy factory foil taping in these areas was one of the first things I did when it was new. I'm sure this made a positive difference with efficiency and air flow.
Steve
Thanks for the advice Steve....I will definately be doing this on Saturday. Maybe that is one reason our's won't keep up with the heat either.
therink
Rochester
Posted: 07/24/12 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
kckettridge wrote:
Let me know what you find. make sure the foil tape is neat and providing good seal in there as well. Redoing the creappy factory foil taping in these areas was one of the first things I did when it was new. I'm sure this made a positive difference with efficiency and air flow.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
