unkledaddy
East Tennessee, USA
Good Morning,
I have a 2002 Monaco Windsor with a Eaton rear axle/differential.
I am in the process of changing the gear oil and the owners manual
specifies Pennzoil Gear Plus Super-EW 75W90 Synthetic or something
with API GL-5.
I can purchase some Castrol Syngear 75W90 Synthetic with a GL-5 rating that is described as being acceptable for Eaton Road Ranger and Rockwell extended warranties, and I just need some reassurance that it's OK for me to use. I don't want to put 14 quarts of it in the differential only to find out there's a service bulletin saying not to.
Thanks in advance.
Ya'll be safe out there!
Pete & Sue
Triker33
Homestead, FL
OK for you to use it. GL-5 Synthetic made by any manufactures will work.
hooligan
Pensacola,FL
Pete: Here is the Eaton Approved lubricants. Includes extended change interval lubricants.
Eaton Approved Lubricants
Hooligan U.S. Coast Guard Ret.
2000 GeorgieBoy Landau DP
2008 SUZUKI Grand Vitara TOAD
1 Pug "Lily", 1 Newfoundland, "George"
00 BUCK
NE Ohio
Triker33 wrote: OK for you to use it. GL-5 Synthetic made by any manufactures will work.
agree
2011 Newmar - VENTANA -- with COMFORT DRIVE
2011 Jeep Wrangler Unlimited Sahara
Blue Ox Aventa LX Tow bar w/ Roadmaster adapters
AirForce One brake system
Life Member GOOD SAM Club
FMCA Member
If your not the lead dog
the view never changes
hooligan
Pensacola,FL
Pete: That link above takes you to the main Roadranger page. The document is here.
Roadranger approved lubricants
zmotorsports
Utah
As others have mentioned, any GL-5 rated lubricant is sufficient. I just changed mine again last year and used Valvoline synthetic gear oil.
Mike.
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
2011 Jeep Unlimited Rubicon
fischer
livingston, tx
How often do you change rear dif on a. DP ? My gasser says rear dif is for life just asking
2005 Southwind 32vs F53 Retired
2006 Jeep Liberty 4x4
Blue ox Tow Bar
hooligan
Pensacola,FL
Depends on manufacturer. Eaton, Meritor etc.
My MH has Meritor rear drive, fluid change interval is 50,000 miles or 1 year for dino oil or 250,000miles/ 3 yr for synthetic.
zmotorsports
Utah
I replace mine every four years. I replaced it in 2007 when I took ownership and again last year, along with the transmission fluid and hydraulic fluid.
Mike.
