CT_WANDERER
E. Lyme, CT
IS your PI before the T/S or after the T/S?
Farmhawk
Libby, MT
Contact Progressive Industries they are very knowledgeable and willing to help.
Brent and Gina
Arkansas
MrWizard wrote: sounds like a transient spike on the power line when the a/c refused to start from the 'too small' generator
you blew out something on the ems control
now you need to remove, to replace it or repair it
Sounds logical to me cause it's not working. I do wonder why a PI would blow with a one-time occurrence. Seems like they'd handle any juice issues over and over. It's an expensive one-time thing. What are your thoughts on that?
Brent and Gina
Arkansas
CT_WANDERER wrote: IS your PI before the T/S or after the T/S?
Man, I must need a second cup of coffee. I can't glean what "T/S" is even in the context of your post.
Brent and Gina
Arkansas
Farmhawk wrote: Contact Progressive Industries they are very knowledgeable and willing to help.
Great advice and of course, I did today. They ran through some tests with me. He can't say the cause, but he's sending a board and a new digital meter with a new cable to cover all the possibilities. I praised his company highly and now I'll do it publicly. They only want me to return what I replace. Awesome company.
larry cad
ohio
Brent and Gina wrote: Farmhawk wrote: Contact Progressive Industries they are very knowledgeable and willing to help.
Great news. Be sure to tell us if you ever figure out what a T/S is too.
Our Travel Blog
EckE
Lyons, KS
Brent, how about Transfer Switch
2005 Holiday Rambler 36WDD Vacationer
larry cad
ohio
EckE, I do believe you got it! Congratulations, I think.
CT_WANDERER
E. Lyme, CT
EckE wrote: Brent, how about Transfer Switch
you have it. I thought T/S would not be a problem. Some people have the PI installed before the transfer switch and some after the tranfer switch. If it was after the transfer switch, it could be the contacts are not closing on the Transfer switch. Since you said you had nothing showing on the PI monitor panel.
I have my PI after the Transfer switch.
Brent and Gina
Arkansas
I have the PI installed right next to breaker panel after the TS. I do have the generator capable setup. Should I connect the generator there in front of fiver vs what I did which was to step down the 50a input cord? Did I do a no-no? If the front generator setup is the preferred or proper method, can you reference a setup I can learn from that uses a small 2000w generator. Would this alleviate my generator open ground issue (code E2) noted on the PI?
