RV.Net Open Roads Forum: Front AC not working when on Generator Power
 > Front AC not working when on Generator Power
fischerj
Baton Rouge
Posted: 07/11/12 05:55am Link  |  Quote  |  Print  |  Notify Moderator
It is a 30 AMP Generator.
Also, where would the breaker on the generator be located? I can't seem to find it at first glance.
Thanks,
Jay
bsinmich
Holland, MI
Posted: 07/11/12 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Do you know what kind of MH and what kind of generator? That info would be a big help in helping you. Generators are usually rated in watts or Kw, not amps in an RV.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
fischerj
Baton Rouge
Posted: 07/11/12 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Where would the Automatic Transfer Switch be located?
Thanks,
Jay
fischerj
Baton Rouge
Posted: 07/11/12 06:12am Link  |  Quote  |  Print  |  Notify Moderator
The motorhome is a 1994 Allegro Bay Diesel Pusher with a Propane generator. I think it is an Onan but I'll have to check on that and post it later on today.
bsinmich
Holland, MI
Posted: 07/11/12 08:19am Link  |  Quote  |  Print  |  Notify Moderator
When you get the model # also get any other numbers you might find. The Onan website will give you good pictures of where everything is located on your specificmodel. Typically you will find the comparable model will be downrated about 10% for propane over gasoline. What would be a 4000 watt on gas will be 3600 on propane.
fischerj
Baton Rouge
Posted: 07/13/12 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys, I figured it out. One of the two breakers at the generator was tripped. Thanks again for all your support.
LaPalmaMama
Posted: 09/04/12 10:02am Link  |  Quote  |  Print  |  Notify Moderator
I love how I can come to this forum, didn't even have to ask a question and found the exact answer to fix my ac problem
