RV.Net Open Roads Forum: Class A Motorhomes: awning
STEVEP220
VA.
Posted: 07/09/12 07:28am Link  |  Print  |  Notify Moderator
Help I can't get the awning to come out. I started to put my awning out (manual awning),I noticed the lever was already in the down position. I unlocked all of the safety locking devices and looked for the pull strap to pull the awning out. couldn't find it. I think it is up inside the awning. I tried to pull on the arms out ot get to the strap but they won't move at all. Any ideas on how to get it out. I can get on roof but don't have a ladder tall enough to get up to ladder.
powderman426
N. E. Ohio/The Villages, Fla
Posted: 07/09/12 07:41am Link  |  Print  |  Notify Moderator
I would move the latch from unlock to lock, And then back again. It may have been stuck But if it is unlatched it should roll out manually. The only thing the strap does it make it easier but some people never have or use a strap. Good luck.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Johnworth914
USA!
Posted: 07/09/12 07:50am Link  |  Print  |  Notify Moderator
sometimes the arms get stuck. try lifting each arm and pulling it out from the awning.
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!">
Sloop Smitten
San Marcos, CA
Posted: 07/09/12 04:05pm Link  |  Print  |  Notify Moderator
Tie a rope around the arm and slide it up to the top. That should give you the leverage you need to pull out the awning.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
DSDP Don
Moorpark, Ca
Posted: 07/09/12 04:14pm Link  |  Print  |  Notify Moderator
Steve.....I think powderman426 has the right idea. Often when they're stuck, you have to grab the roller tube with one hand and manually twist it a 1/4" or so to get the latch to move one way or the other.
Don & Mary
2014 Newmar Dutch Star 4018 - All Electric
Cummins 450ISL
2016 GMC Canyon 4WD Crew Cab
ferndaleflyer
everywhere
Posted: 07/09/12 04:57pm Link  |  Print  |  Notify Moderator
Call "GOOD SAM"
