RV.Net Open Roads Forum: Tech Issues: Replacement of an Aqua Magic Starlite/Galaxy toilet
 > Replacement of an Aqua Magic Starlite/Galaxy toilet
det62
MD
Posted: 07/09/12 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I am thinking about replacing the toilet, off and on leaks from the valve. Several people have told me that I need the Bravura model for a direct replacement. I really like the looks of the high mount Aqua Magic V with a hand flush. What problems would I have with the bolt holes lining up with the V model?
1994 Georgie Boy Pursuit 32 foot Class A
Debbie (owner, pilot and navigator)
Steve (campfire starter)
Matthew - age 17 Got Fish ??
Rebecca - age 16 Got Wi-fi ??
Cool Canuck
Winnipeg, MB, Canada
Posted: 07/09/12 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I will never have another plastic toilet. Porcelain and or china bowl is the only way for me.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
rvluversnc93
Thomasville NC
Posted: 07/10/12 07:57am Link  |  Quote  |  Print  |  Notify Moderator
The thetford bravura is the closest to what you have all holes line up etc... like the above poster said porcelain toilet is the better choice and price in not much different.
Happy Camping !!
Derek - FD Battalion Chief
Teresa - Technology Assistant
Hers - 11 Dodge Charger
His - 04.5 Dodge Ram 2500 CTD Q-Cab
(Real Trucks Don't Have SparkPlugs)
2011 Canyon Trail Fiver
Clay L
Sioux Falls, South Dakota
Posted: 07/10/12 11:55am Link  |  Quote  |  Print  |  Notify Moderator
If you go to this SITE
you can download a chart that shows which Thetford and Sealand toilets replace the one you have. It gives some dimensions of the various models and indicates which ones are direct replacements. Of course the water line might have to lengthened or shortened.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
PUCampin
Castaic
Posted: 07/10/12 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the Aquamagic V with a Style II. The Aquamagic V is a piece of junk. It has almost no replaceable parts, so if something not on that very short parts list fails, you throw out the whole thing. On mine the seal for the shaft that linked the flush handle to the blade dried up and was allowing black tank odor into my TT. The seal was not replaceable. Also, the Aquamagic V has a molded base, not a tube, and thus a large "splash chamber" directly below the bowl. There are nooks and crannies that stuff gets into that is almost impossible to clean. I would not reccomend the Aquamagic V as a replacement. The style II only needs a little bit more distance to wall than the Aquamagic V, and can be completely rebuilt. I did have to alter the PEX water line a little. That was more difficult than replacing the toilet.
2007 Expedition EL 4x4 Tow pkg
1981 Palomino Pony, the PopUp (Sold)
2006 Pioneer 180CK (No more PUcampin!)
Me DW and the 3 in 3
DD 2006, DS 2007, DD 2008
Clay L
Posted: 07/10/12 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with your comments on the Aquamagic V.
After the second set of cables broke on mine I replaced it with a Bravura. It has worked well for about 7 years and does not have that dumb splash chamber you spoke of that can't be cleaned.
det62
MD
Posted: 07/10/12 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone !! Looks like I will order a Bravura
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/10/12 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
We really like our porcelain bowl Style Plus. The installation took less than 30 minutes, including adding an inline shut off in the water line.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
garry1p
Oklahoma
Posted: 07/10/12 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
If you have to extend the water line use a Shark Bite with a built in shut off.
Available at most any hardware store $8 to $10 not only will you have a shutoff to the toilet but no clamps required.
If the bolt holes do not match up the flange screws off so taping it around 1/4 turn with a screwdriver and a hammer to line up or as in my last install I had to cut new holes in the flange since it would NOT move.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
