RV.Net Open Roads Forum: Class A Motorhomes: Portable Fesh Water Tote Tanks?
 > Portable Fesh Water Tote Tanks?
supercub
Modesto CA
Posted: 07/09/12 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
When using a portable tank for fresh water.......how do you get the water from the portable tank into the holding tank in your motorhome? I assume a pump.........suggestions on pumps and also tote tanks. Thanks
Brian
hershey
Albuquerque,(fulltime) NM, USA
Posted: 07/09/12 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Some RV's have a gravity fill so you just pour it in.
Other without a gravity fill have a means of pumping antifreeze into the system so you just use the antifreeze pickup to pull the water into the tank with a bit of ingenious modification.
Or use a seperate pump.
As for carrying the water? I carry three five gallon collapsible jugs. When empty they lay flat for storage, great because I seldom have a need for them.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
skipnchar
Topeka or somewhere else
Posted: 07/09/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't have a gravity fill it may be much easier to take your RV to the water source then to hand carry it. With a gravity fill system you just pick up the jug and pour it in.
crasster
Dallas
Posted: 07/09/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
We have used a small pump that fits on the end of a drill. It just pumps the water out from the drill speed.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
othertonka
Stockton, CA
Posted: 07/09/12 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my water pump with a better one and kept the old one, mounted it on a board, fitted it with wires and aligator clips and since my gravity fill for my water tank is right near the entry door and my battery is under the steps it makes it very convient to hook up the pump to the battery, stick the water pump intake hose into, in my case a 6 gallon water container, and pump it right into the gravity fill opening through the output hose. I could just lift the container up and dump it in the opening but 50 lbs of water is just a little too heavy for me. I use a small collapsible hand truck to haul the 6 gallons of water back and forth.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
myowneq
Louisiana
Posted: 07/09/12 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Academy has a six gallon rigid plastic tote for $15. It's what I plan to use when I go to the races in November. They come with a pour spout.
2010 F150 XLT 4x4 SCab 5.4L
2007 Grand Surveyor
fourmat
NJ
Posted: 07/10/12 06:11am Link  |  Quote  |  Print  |  Notify Moderator
I just use the winterizing hose pump ulls it right up
2009 Challenger
myowneq
Louisiana
Posted: 07/10/12 06:14am Link  |  Quote  |  Print  |  Notify Moderator
I just realized this was the Class A forum. I doubt five or six of those totes would help you much. So never mind me.
grldst
Dallas, GA
Posted: 07/10/12 08:53am Link  |  Quote  |  Print  |  Notify Moderator
We have a 60 gal "water bladder" that we use for additional water. We use an electric water pump to transfer the water into the RV. Pump was purchased from "Northern Tool". Price was around $40.00.
msmith1199
Central, CA
Posted: 07/10/12 08:59am Link  |  Quote  |  Print  |  Notify Moderator
The problem with using the internal system to pump water is on most motorhomes the internal system would not pump into the tank, but into the plumbing for use at the faucets. A few months back somebody posted an idea on here that I never thought of. He rigged a hose fitting on his external shower. He then hooked the shower to the input to fill the water tank. He would then pump the water using the internal water pump into the plumbing and turn on the shower and let it pump the water into the holding tank. This seems like the simplest and cheapest method to do this.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
