RV.Net Open Roads Forum: Tech Issues: Grey tank overflow?
 > Grey tank overflow?
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 07/10/12 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
YuP, Leaky fitting or cracked tank.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, ClearSpot 4G+,
http://www.kayepics.com
Old-Biscuit
Across the USA
Posted: 07/10/12 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Vent line fitting/seal gasket is leaking
Drain line into tank fitting/seal/gasket is leaking
Crack in top of tank
You have a leak!
Previous owner was aware of leak..that's why 'hole' is punched in low spot of underbelly.
Need to drop underbelly...check for mold/mildew and locate/fix cause of grey water leaking.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
bigcampnut
North Carolina
Posted: 07/16/12 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
After a trip to CW, the verdict is a cracked grey tank at the top near the neck portion. A few weeks to order the warranty replacement, and we will be good to go!
