RV.Net Open Roads Forum: Fifth-Wheels: Fifth Wheel Trailer brakes HELP!
 > Fifth Wheel Trailer brakes HELP!
Lynn608
Athol, Ma
Posted: 07/10/12 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Good morning all,
I have a six year old Tekonsha Voyager braking system on my Chevy 250 which is suddenly acting erratically. I'm planning on replacing it with the Tekonsha P3 digital read out. Has anyone had any experience with this model. Would appreciate feed back.
Towing a 35ft Fifth wheel weighs around 11,000 all up.
Thanks
Cool Canuck
Winnipeg, MB, Canada
Posted: 07/10/12 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Best move you'll ever make. ..... with brake controllers that is.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
tvman44
Southwest Louisiana
Posted: 07/10/12 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Both, the P3 is worlds above the voyager.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Brewurown
Morganton, NC
Posted: 07/10/12 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I had a Voyager when I had a 7000 lb TT and it worked SO SO. When I replaced the TT with a 5er about 12000 lbs, it seemed that I had to adjust the controller every time I traveled. I replaced it with a P2, set it once and forget it. It works correctly every time. Best move I made.
Al & Eva
2007.5 2500 Dodge 6.7
2010 Montana Mountaineer 335 RET
Bessie the Bassett (in doggie heaven 4/10/13)
Little Bit the Terrier (in doggie heaven 5/14/12)
Hickory Foothills Good Sam Chapter member
jdog
Some Place
Posted: 07/10/12 10:47am Link  |  Quote  |  Print  |  Notify Moderator
This mistake
Randu
South Central Michigan
Posted: 07/10/12 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Lynn608 wrote:
Good morning all,
Thanks
By erratic do mean brakes and then no brakes or moderate brakes? Problem comes and goes? Sometimes acts like like the trailer brakes are pulsating on and off?
I had a short to ground during braking on 2 different trailers. My first thought was controller but problem turned out to be chaffed wire inside axle tube as wire is routed to the wheels. Wire had multiple small chafes from axle tube rust that caused burn thru and shorts. Randu
2004 GMC 2500HD 8.1 Big Block gas
2008 Mobile Suites 36TK3
PikeRoadWarrior
Pike Road, Alabama
Posted: 07/10/12 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not familiar with the Voyager, but the P2 (and I think the P3, I'm not sure) will give you feedback on wiring problems through the display. If you do have electrical issues, the P2 may indicate them for you.
2004.5 Dodge 2500 Cummins 4x4
2009 Sabre 31BHDS
CharmCityRV
Central Maryland
Posted: 07/10/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Another Tekonsha user here that thought the controller was going up, but in fact it was indicating correctly a ground to short the same as Randu.
8ntw8tn
Southeast Iowa
Posted: 07/11/12 04:30am Link  |  Quote  |  Print  |  Notify Moderator
I have the P2 model. It's great and I think you'd really like having the P3. That said, everytime in the past I thought I had a controller problem it turned out to be a wiring problem. I'd suggest a thorough check of the system before replacing the controller. Unless of course you want the controller anyway. You just may get a new controller AND have to repair some wiring. Hope this helps.
'04.5 Dodge Ram 3500 Quad cab 4x4 SLT dually w/5.9 H.O. Cummins; PacBrake; Smarty Jr.; Raptor 100 lift pump; egt & tranny temp guages;rebuilt tranny;
'06 Carriage Cameo LXI F35CKQ w/MorRyde pinbox
Det 1 56th SOWg
Cool Canuck
Posted: 07/11/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
While it may indeed be a wiring problem, I had a Tekonsha Voyager controller go bad after 6 years of faithful service. It got so I could not set it so the manual braking would be effective once the inertial braking was set properly. If I set it so I had manual braking, the inertial braking was violent and locked up the trailer brakes immediately. Replaced with a P3 and never looked back....that is until I replaced the P3 with a new truck.
