RV.Net Open Roads Forum: extend driving range of Sprinter based C
 > extend driving range of Sprinter based C
Coach-man
Posted: 07/10/12 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
To those who own Sprinter based Class C's, do you find the 20 gallon fuel tank a problem? If so what have you done to extend the range in you rig?
l001952119
Granbury, TX
Posted: 07/10/12 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
The tank is 26 gallons! It will get you approximately 250 miles plus and that is a good time to take a break from driving and fill the tank! I have a 2010, 3500 chassis, so your tank may be a different size.
Coach-man
Posted: 07/10/12 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I think mine is 24 gallons, and I get about 262 miles range. Sometimes that is a good point to stop, but there are times when I would like to "push on" and was hoping for some ideas?
gerrym51
unknown
Posted: 07/10/12 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
the sprinter and sprinter chassis fuel tank is 26.4 gallons
transfer flow makes auxiary fuel tanks they also make a repacement tank that is bigger. not cheap
midnightsadie
ohio
Posted: 07/10/12 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
mines on the 3500 chassis 26gal every body needs a break even 15min to refuel is a big help.
mlts22
Austin, Texas
Posted: 07/10/12 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you consider the MPG of a Sprinter (guessing 15 or so), it is not too bad. A MH getting 6-9 needs almost twice the volume of fuel for the same amount of miles, so in a way it evens out.
If I were boondocking with a diesel generator, I'd probably consider a cargo carrier for the rear hitch and some diesel cans (perhaps with some additives added to prevent algae from forming and maybe another additive to prevent gelling if going into cold temperatures.)
If I boondocked often, I'd consider paying the price premium for Rotopax mounts and containers. That way, it would be easy to stack a number of four gallon containers, and ensure that they are unavailable to sticky fingers with just a twist of a handle and pushing in a locking plunger.
midnightsadie
ohio
Posted: 07/10/12 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
midnightsadie
ohio
Posted: 07/10/12 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
15mpg??? mine clocks over 20mpg on each tank. if you like the rv,s there great
gerrym51
unknown
Posted: 07/10/12 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
you keep posting about this. You have a 2007 vehicle that uses 2006
sprinter.
old style before bigger engine and modern emissions controls.
NO COMPARISON
NewsW
US
Posted: 07/10/12 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Auxiliary Fuel Tank: Our 17.5 gal auxiliary fuel tank is designed for the 07 and newer Sprinter Vans and our 13 gal auxiliary tank is designed for the 07 and newer Sprinter Cab Chassis and Class C motorhomes. Depending on mpg, you can extend your driving range to over 800 miles on the vans and 575 on the motorhomes! The tanks are Aluminum and act as an extension of the factory tank. There are no fuel level floats or auxiliary fuel pumps to hassle with. The tanks have internal baffles to reduce fuel sloshing and has a drain plug, which can be removed to insert a fitting for an additional fuel outlet. Installation is simple and takes about 4-6 hours. You do need to drop the factory tank and you must cut into the factory fuel tank to establish the cross over between the two tanks. Other than the fuel level dropping much more slowly, the factory fuel gauge functions normally. The last 1/4 of the factory tank registers and drops normal, and the 5 gallon reserve light functions normally. When filling the tanks, the last 6-7 gallons fill more slowly than 35 or so gallons. If you park nose down or drive down a steep incline for more than few minutes or so, fuel from the auxiliary tank (depending on its level) may/will fill the factory tank. Because of the one way valve at the fill neck just inside of the tank, the fuel will not go back into the auxiliary tank and the fuel gauge will reflect that.
The kit is special order and build time is approximately 3-4 weeks (sooner depending on our schedule). We do require a 50% non-refundable deposit to get the order started. The 144" 3500 Van tank is slightly different in length and has a 16.5 gal capacity. The 54"x12" area on the outboard side of the factory tank must be completely open and unobstructed for the tank to install properly. A 27 gal tank is available but requires installing a transfer pump and optional fuel level sending unit (call for estimates). Our auxiliary tanks are well designed and well made but are considered for off road use only. These auxiliary fuel tanks are not DOT approved. The 17.5 gal fuel tank is now available for $1495.00 plus shipping and handling and the 13 gal fuel tank is $1495.00 plus shipping and handling.
At that price, consider this:
