AZJIM1
Phoenix, AZ
How many people here rotate theirs? How often?
It would seem like a good idea to balance tread wear, although most people never wear out their trailer tires. Most people probably don't even put 10,000 miles on a set of trailer tires in their 5-6 year life. And including the spare in the rotation would get a little use out of that extra tire that (hopefully) a lot of us never need.
I have never even considered rotating my radial trailer tires because I thought (apparently incorrectly) that you couldn't swap sides with radials but that rule has changed over time.
1999 Coleman Westlake that replaced STOLEN!!! 1987 Coleman Sequoia
2006 Honda Odyssey
Me, Wife, Daughter, Son
A Pack (Two) of Australian Shepherds
MY CAMPSITE, PLACES WE HAVE SEEN, CAMPER & MOD PICS HERE
and
MY CAMPSITES MAP HERE
robsouth
Near Atlanta, GA
Never have.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
Wills250psd
walnutcove NC
They dont seem to last long enough to rotate, just replace
Dick_B
Palos Heights, IL USA
You could search this Forum for `rotate tires' and read 40 responses already.
My guess is that most RVers don't rotate their tires but that doesn't make it the best thing to do. I rotate mine about every two years AND incorporate my two spares into the mix.
If you dig around you will find that spares lose something when not used. I can't explain it but I read it somewhere.
Maybe in www.michelinrvtires.com
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Francesca Knowles
Port Hadlock, Washington
If I had a dual axle trailer, I'd rotate...
It's my understanding that the rears are subject to "scrubbing" during cornering, and rotating will spread the resulting "extra" wear out evenly over the four tires.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
coolbreeze01
Redding, Ca
I don't rotate trailer tires. If one or two wore out prematurely, I would suspect an alignment problem.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
Dave H M
IL
never
I don't know how many miles it would take to show some wear on my fiver tires. They always look new, even when they are removed for new ones.
MitchF150
Washington, the State
I do it just because I will have both tires off on that side anyway when I'm checking the brakes in the Spring time...
I swap the front/rear tires on the same side of trailer.
Don't notice any uneven wear to begin with, but figure it can't hurt as I've already done most of the work already!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
pjhansman
North Eastern Ontario, Canada
My tires rotate every time I pull the 5ver
Other than that, I don't bother. They'll be changed before there's much wear.
Phil & Rae.....and 2 feline furkids to make travel interesting
2011 Keystone Laredo 316RL
2005 Ford F250 SD, 6L PSD, 4x4
Yamaha EF3000iSE/B Inverter Generator
jetboater454
Camping or home
I rotate my 6 tires every year when I check the brakes.They are off so why not.And with a tri-axle the rears scrub a lot in tight turns.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
